Xray T3 2011
#1517
I'll still be waiting for a better designed shock like the Tamiyas. Although, I'm sure many have already purchased the other brand shocks. Why be stubborn Xray? I'll buy them as an upgrade.
#1518
Orange aluminum camber links, aluminum shock retainers, shock cap with holes? I still can't get zero rebound with the holes in the caps.
#1519
#1520
I think there are many that agree the shocks are much harder to get the desired rebound than others designs. They are a pain in the @ss. How many people have to complain about them? It's bad business to tell customers they are wrong and on top of it promise a video that never came. Sorry, but I speak the truth.
#1521
#1522
I've been going to Omaha for every Sunday points race this winter season, everyone up there knows i run Xray and will ask me questions, but I have yet to meet you, or if i have you have never asked for any help. (FYI I will miss the race next weekend for the 13.5 race in albuqueree) Maybe instead of posting all your problems on here you should come race and get some help.
#1524
Team EAM
Ive been to a LOT of races everywhere and can only remember of 1 time I have seen someone with shocks on their car other than Xray shocks. Seen a few pics on here but never at the track other than the 1 time.
EA
#1525
thank you that explains a lot and helps.
From what I have found you can not get zero rebound on the shock. What I consider Zero rebound is where you compress the shock and it sits there for a second then slowly creeps out 1/4 inch or so. That is zero rebound as there is not enough pressure to change the feel of the shock shaft when you push it in. A shock with rebound will feel stiffer at the bottom of compression and then "pop" right back out to a point. I believe this is what Paul considers zero rebound as well. Maybe someone else has a better method to achieve a truly dead shock.
EA
EA
#1526
#1527
Guys...I started my build and have two questions.
1) Manual says to use the 3.5mm plastic caps only with Alu ball diffs or multi-diff. So it means I should use it for the rear dog-bones or don't use them at all?
2) Manual indicates to install composite shim 3.6.2mm while installing steering linkage. Based on the work-flow of the build, I have no more composite shims.
I have a huge table I use for projects, etc and have each bag opened and identified...carefully going through each along my build.
Is this an optional tip I can go ahead without it for now or is this a must install shim?
I have carefully reviewed the entire build.. in case I misplaced parts or used wrong parts... but it seems I am just missing the two shims.
#1528
#1529
Thanks... I'll order the shims and install the caps in the rear
#1530
