Like Tree4Likes
Tamiya TRF417
Old 02-21-2013, 09:13 AM
  #4756
Trader Rating: 32 (100%+)
[QUOTE=spacendeman;11843535]
Originally Posted by grauco
Don't know about the damper stay.. but if you want a complete V5 I also thought that you should buy new bulkheads as they are 0.5 or 1.0mm higher then the X ones.. But please someone correct me if I'm wrong.
My GUESS is that is the difference in the damper stays as well. Perhaps cut shorter to accommodate the taller bulkheads? Maybe someone can measure this? To see if the shock mounting points are the same height on both cars. Anyone converting their X to a V5 might be better off keeping the X damper stays if this is the case.
ittjv is offline
Old 02-21-2013, 01:10 PM
  #4757
sakaguchinet's Avatar
Hi,
the proto car features a new upperdeck construction which is quite similar to Yokomo. I am sure it will work awesome!
sakaguchinet is offline
Old 02-21-2013, 01:16 PM
  #4758
CraigM's Avatar
Trader Rating: 34 (100%+)
The rear damper stay is the same part as on the 417x so it's +0.5mm. The front damper stay is also the same height but includes some additional holes on the inside. I've never used the front shocks that laid down so I wouldn't worry about upgrading unless you somehow break a tower
CraigM is offline
Old 02-21-2013, 02:44 PM
  #4759
Thanks for clearing that up Craig.
ittjv is offline
Old 02-22-2013, 12:47 AM
  #4760
skyball's Avatar
Hey Dai,
could you post a picture?
Christian
skyball is offline
Old 02-22-2013, 02:55 AM
  #4761
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Dragobrat
Hi guys, can someone please confirm for me that these spur gears are the correct ones for the trf417 v5 ?
http://banzaihobby.com/radio-control...-spur-gear-64p
XENON RACING PRS-6-116 PR Spur Gear 64P 116T
I have a trf417 v5 on the way and would like to order some 64pitch spur gears for it.
PLus I will get the spacer - Panaracer 417 spur gear spacer (#PRS-SPC).
Thanks in advance.
These are the correct spur gears. 116 is probably a bit large for this car, normally for modified we run 111 or 113 just like what comes in the kit.
Sorry to keep bringing up the Spur issue, but what's the difference between the
PRS spurs http://banzaihobby.com/radio-control...-spur-gear-64p
and the VSS spurs http://banzaihobby.com/radio-control...-64p-spur-gear
Sith Lord is offline
Old 02-22-2013, 07:56 AM
  #4762
not sure whos car it is but theres some interesting uses of yokomo parts on this 417v5?
Smartypants is offline
Old 02-22-2013, 02:19 PM
  #4763
Trader Rating: 20 (100%+)
That is Groskamps car!!! You can tell by the Orion equiment.
Sean Williams is offline
Old 02-22-2013, 03:22 PM
  #4764
narcotiks's Avatar
Could you point out the yokomo parts? i can't spot any so far...correct me if i'm wrong but the top deck is a V5 top deck
Edit: just spotted the motor bulkheads
narcotiks is offline
Old 02-22-2013, 03:38 PM
  #4765
over gear's Avatar
Trader Rating: 18 (100%+)
yokomo motor mount
over gear is offline
Old 02-22-2013, 05:59 PM
  #4766
Sith Lord's Avatar
Being new to Tamiya, can I ask Why Yokomo aren't owned by Tamiya, are they? Why would factory drivers be using other company parts? Or is that something that all factories do?
Old 02-22-2013, 07:16 PM
  #4767
Trader Rating: 27 (100%+)
Often testing near-compatible parts is subtle, concealed and out of sight. Todays top-tier cars share a lot in terms of geometry and design.
There is a video from TITC in which a camera man is shooting video in the various pit rooms. While visiting the Tamiya, it is clear that the top Tamiya engineers cover up this mod area of the car. The picture above is a lucky picture of what they have going.
If if works out - they will surely have a Tamiya-blue left/right motor mount for asphalt racing.
I think it is great the engineers have a more open mind in what is working for other programs.
MDawson is offline
Old 02-22-2013, 11:37 PM
  #4768
Dusttt's Avatar
Trader Rating: 144 (100%+)
she is nearly done. I am contemplating taking this car to bed with me
Dusttt is offline
Old 02-22-2013, 11:44 PM
  #4769
TryHard's Avatar
It's interesting to catch that, someones been lucky with the camera.... It's also interesting that they are testing that configuration. On my current vehicle (Serpent Eryx) we can run both a 417V5 style mount, or the BD7 style mount setup out of the box I found the BD7 style to give more mid-rotation than the V5 setup...
Ed
TryHard is offline
Old 02-23-2013, 12:54 AM
  #4770
How are you finding the serpent ed?
On my 417 i keep suffering from lift off over steer, current setup is 120wt diff oil ( just under 1500cst) 2deg rear camber 1deg front camber, 3 deg rear toe, 0 front toe, 6 frt 5 rear droop, 40wt shock oil, tamiya blue white springs hardest of the 2 on front, 1c fr Fr split 1c fr rr, 1xa split rr fr 1e rr rr. Rear camber links 3 under inside and outside, front camber links 4 inside 0 outside, front shock fully upright rears half way.
Any ideas. Thanks
scytherat is offline
