Team Associated TC6 Thread >
Like Tree20Likes
Old 07-15-2011, 04:40 AM
  #3226
I am sorry Roger but I cannot visualise how a pinion does not fit a motor shaft and spur gear on a TC6.
Maybe make a pic of your pinion?
olly986 is offline
Old 07-15-2011, 04:44 AM
  #3227
and I am running on long sweeping tracks also, 2 different ones , one even more 1/5th scale than 1/8 1/10 scales ic and 7.57 is very good and fast.
olly986 is offline
Old 07-15-2011, 04:54 AM
  #3228
roger999's Avatar
ok, will try 7 when ill be on the track. About pinion will do pics evening.
roger999 is offline
Old 07-15-2011, 09:30 AM
  #3229
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by roger999
speed passion, and it doesn't want to seat on flat surface always... Depends what pinion i have. Xenon makes pinion with 4 holes so is no pobs, but different doesn't.
I am pretty sure this is a motor problem...I used to have issues with this with some of my speed passion motors a while back. I think some of the screw holes are not tapped very straight...trying turning the motor and using other holes if possible.
artwork is offline
Old 07-15-2011, 09:48 AM
  #3230
Yeah, this was an issue for a very short period of time. All fixed with the new batches though.
Danny-b23 is offline
Old 07-15-2011, 10:00 AM
  #3231
roger999's Avatar
maybe guys, but that is only on few pinions, xenon and kawada pinions are ok. they fit no problems because xenon have 4 holes and they are thinner on head, same with kawada.
roger999 is offline
Old 07-15-2011, 11:30 AM
  #3232
geeunit1014's Avatar
Trader Rating: 14 (100%+)
I saw on my friends car, LRP motor, PRS pinions, that the shank on the pinion was long enough that it didnt sit on the flat spot of the shaft. You would have to dremel the flat spot back a little bit farther. I seem to recall some issues like this a while back with Duo motors as well.
geeunit1014 is offline
Old 07-15-2011, 11:36 AM
  #3233
roger999's Avatar
that is only with 3 pinions what i have, so i thought easier will be order different pinions like xenon and i did it so the problem is sorted
thanks to everyone for help!!!
roger999 is offline
Old 07-15-2011, 03:44 PM
  #3234
Maybell's Avatar
With some pinion/motor combos, you have to either chamfer the end of the pinion, or cut the shaft flat spot back farther so the pinion will align with the spur. This is because the motor is so close to center for great weight balance.
There is no need for this modification if using a Reedy Sonic, or LRP X-12 motor.
Maybell is offline
Old 07-15-2011, 05:48 PM
  #3235
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Yo Karl - u done with your car yet? Its been two hours .. what is taking so long?
hanulec is offline
Old 07-15-2011, 05:51 PM
  #3236
You wont find him on here for a while, hes deep in the middle of nowhere in MD surrounded by various wrenches, greases and lubes...
Old 07-15-2011, 05:58 PM
  #3237
hanulec's Avatar
Hopefully he can show tomorrow at Jackson.
Mike - when r u coming out again?
hanulec is offline
Old 07-15-2011, 06:26 PM
  #3238
He will be there tomorrow fo sho. 50-50 chance I'll make it next weekend, but I will 100% be there for nats (only 2 weeks away!?!?).
Old 07-15-2011, 08:49 PM
  #3239
lostinbaja's Avatar
Trader Rating: 15 (100%+)
yes that is not a problem, just not sure where should be pinion, because flat surface on my motor shaft is too short for my pinion. And when i want to set it in one straight line, pinion goes like after that flat space... Hope you understand
My Brother had the same problem. If the pinion was properly lined up with the spur, the grub screw on the pinion would not tighten on the flat area of the motor shaft. Naturally he didn't want to buy another motor with a longer flat machined on the shaft or locate another pinion with a different offset that might work. He brought the motor to work and machined the flat on the shaft long enough to allow the pinion grub screw to tighten on the flat.
lostinbaja is offline
Old 07-15-2011, 10:19 PM
  #3240
can anyone tell me the dimensions of the hubs bearings? (bearings holding CVD in read hub and steering cup) and size of diff ball?
Molala4 is offline
