RCGT....Where is it at now?
#140
This ROCKS !! Thanks Andy for taking some time to address the folks. To all those I've personally talked to....Thanks for your help and input. Our club is excited to offer a true Sportsman level RCGT program again.
BTW , for those that don't know Shawn Palmer from Speed Passion......he's a helluva good guy to deal with. The Cirtix in both forms will be proudly offered to our club members. Irregardless of price, There are some great electronics out there and we all have some options. Now lets get back to racing !!!
BTW, you guys on big tracks are probably right....the 21.5 may seem slow. The VTA folks know this well. But put a 21.5 in it's element ....on a smaller, more technical, more realistic track and watch how it shines !!! Either way, at least now we MAY have that option.
Last edited by Evoracer; 06-11-2010 at 03:11 PM. Reason: I screwed up..what else !
#144
#145
#146
Francis, I think this situation can remain in a state of flux for awhile. The honest answer is that the greater majority of both experienced and inexperienced drivers aren't seeing this as a problem. I suppose the greater answer is that if at some time in the future, based on increased response, it appears there is a widespread tire problem.....it will be looked at. As of now, that doesn't appear to be the case.
#147
Stock foam inserts only rule
On the plus side...it keeps it simple for the newbies and seasoned RCGT guys since you just use what ever comes in the package.
You need to define that it is the stock insert that comes with that particular X-Pattern (ie. D comps comes with slightly different inserts than Pro Comps due to the fact that they are not manufactured at the same location)
Doesn't work (or at least satisfy everyone) unless you are committed to teching the inserts at every event (I've lost count on how many times I/we have been accused of using cheater inserts )
Complaints from people about tire wear at high bite/high speed tracks due to foam insert float/deformation within the tire
Open inserts rule
Great for those wanting to be able to fine tune the performance of they're tires since there are tons of possibilities
Makes it simple since you would only have to tech the tires. Easy to do since they are easily identifiable. Even if an organizer chose a specific compound X-Pattern, the D comps have different (larger) sized hpi racing logos than the Pro Comps (...and the belted one doesn't swell up compared to the non belted ones)
Potential gigantic money pit and frustration because of the same above reason
So..just some FYI's that we've explored/discussed
#148
In a nutshell it's about dreaming of that Falken GT2 Porsche 911 at Laguna Seca, realizing that you're not a racing driver and/or have millions of dollars to do it, and wanting to replicate it in 1/10th scale RC form. Because then you're main goal would be getting a realistic body, realistic livery, BBS wheels etc etc. And not sacrificing any of that for the sake of RC performance.
Anyway, thanks for taking the time to explain where your ideas came from. I raced the Cal Speedway event and as you know I have been a big fan of RCGT since it started. When I was excited and speaking about participating I was accused of trying to ruin the class even though the spirit of the class has nothing to do with ability.
I hope the spirit of the class lives on and it is not bogged down by over regulation and specs which unfortunately seems to be the direction it is headed.
#149
In my opinion, this is what R/C racing should be about and not just an RCGT thing.
Some appear to be trying to over complicate things rather than using the spirit of RCGT as a guide.
