Losi XXX-S
Originally Posted by highwayman
i suggest the FF:
1. more rear toe-in, 3 degress
2. sorex tires
3. sorex b inserts
4. hard dish rims (tamiya, much more or yokomo)
5. red springs
6. front diff
7. mazda body
2. sorex tires
3. sorex b inserts
5. red springs
6. front diff
7. mazda body
Roger that guys, new springs, shocks and the black belt kit,
One question, what is the 540 class?
Thanks again!
Thanks again!
Thanks again!
Thanks again!
Sean
Thanks again!
Thanks again!
Thanks for the info Guys! Is anyone going to the IIC Race in Vegas? Do you know if there are still any opens/hotel rooms left? Thanks again for any info.
On a different note, has anyone had issues with there rear camber link ball studs rubbing the top of there rim? I was using the MF aluminum hubs and put on some graphite ones and am experiencing this. I think the losi short neck ball studs should fix this. Part # losa6008.
Just bought a brand new G+ kit... assembling it right now and it seems like half of the ball cups are ass. (they bind once popped on the ball ends) Anyone else notice this? Are the RPM ball cups better?
Can't wait to get the car up and running. I know it's the older kit, but it seems like there's still lots of bugs to work out on the new car. I just couldn't find anything else that I could simply build out of the box and be happy with. Keeping this thread alive.
If you are having problems with the ballcups you can either buy the rpm's like you mentioned (some of them are ass but some are good) or you can take out one of your ball studs and chuck it into your dremel, them pop on every Losi ball cup you have and spin it for a second or two, thius makes them super smooth
Jusy boought
i just bought a used xxx-s g+ what should i buy for it. i heard something about a black belt kit. any thing else. I also am gonna buy th ecarbon fiber3.0mm shock towers.
The Losi ball ends are better in one reguard as opposed to the RPM. The Losi's are thinner and will not touch or bind on the hubs and carriers like the thicker RPM ones will. Plus, if the brand new ball cups are tight the first time youpop them on then simply take a pair of pliars and gently squeeze the ball cup( when its mounted on the ball). This will " seat the ball inside the ball cup and free it up without causing too much slop. I love Losi kits and have run them forever, but, after several race days your ball cups will get loose if not too loose!!! When, not if, they get too loose then cut a small square of a plastic parts bag about the same size as the ball cup hole but leave the square edges on it. Poke it into the ball cup and pop it back on. When you do this it will take out the slop in between the cup and ball. Good Luck Gents.
Brant
Brant
Brant
The Dynamite motor clamp/heatsink is probably the best bang for the buck accessory I have on my XXX-S... The problem is that, as I understand it, Dynamite has discontinued it -- at least the local hobby shop cannot find it from any of their distributors....
doesnt all the alumanum parts get heavy. im only gonna be doing racing no bashing what so ever. and can you give me a link to the bumper theing. thanks
Mike
Mike
Mike
Mike
Do you guys think i should get the 3.0mm carbon fiber shock towers? i like them because they are lite what do you guys think. Do you now a place were i can pick up a woven carbon fibe chassis?
thanks
Mike
thanks
Mike
