Like Tree2Likes
Losi XXX-S
Old 06-12-2004, 06:46 PM
  #11056
Default Droop?
Hey everyone,
What does 'Droop Height: 2.5' mean? Is it 2.5 mm below parallel with the chassis? Why do all the Losi setup sheets (that I've seen) list droop like this instead of using the standard 'Droop: 5'
Am I completely misunderstanding this? If someone could shed some light on it, it would be appreciated.
Thank You,
Griffin
Griffin is offline
Old 06-12-2004, 06:59 PM
  #11057
The Evicerator
Griffin:
Most of the time they are referring to the setting on the droop guage... IE, 2.5 mm different between the bottom plane of the chassis and the bottom of the set-screw boss...
Steve Weiss is online now
Old 06-12-2004, 07:44 PM
  #11058
Thanks. I kinda guessed that as soon as I posted the question, but appreciate you clarification.
Also, are there two different purple springs? The ones that came with the kit seem to be quite a bit different in color (darker), but lighter in compression then the purples I bought today (20.0) lbs.
What's the deal?
Griffin is offline
Old 06-12-2004, 08:07 PM
  #11059
The Evicerator
Supposedly the only difference is the color... apparently the powder-coater used the wrong color and instead of denying (throwing away) the entire batch, they decided to just use them....
Old 06-13-2004, 05:15 PM
  #11060
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
just wondering, i have the XXX-s RTR, does the black belt kit fit on it and if so, where can i find one because i'm in the middle of a tear down and clean. i want to try this out
JayBee is offline
Old 06-13-2004, 05:32 PM
  #11061
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
The HD belt will work on all XXXS models. Most hobby stores that carry Losi parts can get them, they arent so scarce anymore.
Randy Caster is offline
Old 06-13-2004, 06:11 PM
  #11062
NVisible's Avatar
Been able to find those TRF red dampers Randy? Everywhere ive looked are out of stock
NVisible is offline
Old 06-13-2004, 06:27 PM
  #11063
JayBee's Avatar
Post
does anybody know the part# for the HD belt kit and would it say black belt in the description? i'm checking out stormerhobbies
JayBee is offline
Old 06-13-2004, 06:39 PM
  #11064
JayBee's Avatar
Post
#A3820 maybe??
JayBee is offline
Old 06-13-2004, 06:40 PM
  #11065
mwcet8k's Avatar
http://www.teamlosi.com/newprod/2004..._drivebelt.htm
mwcet8k is offline
Old 06-13-2004, 06:52 PM
  #11066
JayBee's Avatar
Post
hey thanks man, that was the kit i was looking at on stormerhobbies web site. i'm gonna go on ahead and submit my order
JayBee is offline
Old 06-13-2004, 07:34 PM
  #11067
JayBee's Avatar
Post
#A3820 maybe??
oops, it's actually part# LOSA3280
JayBee is offline
Old 06-13-2004, 07:41 PM
  #11068
Nobody has red! I'll either just drop by Tamiya or order a set and buy red caps.
Old 06-13-2004, 08:01 PM
  #11069
JDM_DOHC_SiR's Avatar
Heeeeheh Need some help there Big Guy ... PM me
-Dave
JDM_DOHC_SiR is offline
Old 06-13-2004, 08:14 PM
  #11070
forty6's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSA4&P=7
1 in stock at the time of posting.
forty6 is offline
