Losi XXX-S
#4532
Yes the PRP towers are nice. I have been running with my front camber links in the center top holes for about a month now. With this location you can gain more mid cornering traction and exit traction. With a tight diff, it really makes the car aggressive on corner exit and sweepers but aids in corner entry too. Give it a try!
#4533
Guys I am assembling a xxx-s. It is my first time with this kit though. I am assembling the belt tensioner assembly and the pulley on the tensioner squeezes the spur gear. I did rotate it around clockwise as stated but it is still touching the spur gear and rubbing. Is it supposed to do this??????? or where did i go wrong?
#4539
christopherkee
if find those blue servo mounts and bell crank oder one for me too and i'll just pay you back.
nelly
see yah sat
nelly
see yah sat
#4543
Where did you put the ball stud washer's, and how many?
#4545
Bumpsteer is when you compress the front suspension and the front wheels either go from being straight to tow in or tow out. I installed 2 of the gold losi ball stud washers under the ball stud on the bellcranks to correct it. It might need a little bit more, like a thin armature spacer.
Blake
Blake
