Like Tree2Likes
Losi XXX-S
Old 02-28-2002, 07:08 PM
  #2086
Thanks.
MDM3 is offline
Old 02-28-2002, 08:29 PM
  #2087
Trader Rating: 82 (100%+)
thanks for the replies im getting the adapter this weekend and will try to fit the white RRP spurs. if they rub, ill try the ones from trinity.
marvi is offline
Old 02-28-2002, 09:43 PM
  #2088
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by seamus0g
STLNLST - Yep, I'll be there Sat. I had to run stock on Wed since none of the mod gang showed up... almost fell asleep on the drivers stand the car was so slow. LOL
How was the traction? Some heavy hitter's might show up this weekend so bring da ponies.
STLNLST is offline
Old 02-28-2002, 09:57 PM
  #2089
STARSCREAM's Avatar
mdm3,
something that most people dont know is that you can go fast with any trinity stock motor if you gear and tune it right. those data stickers dont mean squat!! the only way they vary is the power band can vary motor to motor. so if you know how to set them up and gear each motor right, youll be just as fast with whatever.
yes, that means two p2k2's can have a slightly different power band and nead to be geared differently.
it is true though that a p2k is better for small, tight tracks and a green machine 3 is better for large, sweeping tracks.
STARSCREAM is offline
Old 02-28-2002, 10:16 PM
  #2090
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
yok guy......try one of these things.....it is all in the caster....first try taking out the 4 deg caster blocks...if that helps your ok...it did on mine...
if it does not put in 2 deg blocks...keep messing with the kick and caster...you will find it....also try standing the front shocks up a bit...you should be ok....
Matt M. is offline
Old 02-28-2002, 11:43 PM
  #2091
seamus0g's Avatar
I finally figured out the setup secret, so the traction was excellent. The track is also realy fast and flowing; I dipped into the mid 13s with the spec tires and a 10x2 during practice. And the ponies are no problem, I got Luna power under the hood now. heh
seamus0g is offline
Old 03-01-2002, 12:50 AM
  #2092
Yok guy
Yes as Mr losi suggests try running 2deg caster rather than 4. I have found that doing this is very beneficial. also as Mr losi also suggests if the front shocks are more upright thaen the steering response is a bit faster with a little less understeer. personally depending on the track I only ever change between the very inside hole (layed right down) and the next one out. I also run slightly harder springs than you mention. I use purple up front and green in the rear. I find that this setup is the best starting point track to track and I can then simply fine tune shock position to get the max.
try it it will work!!
Rich
MDM3 yes I got your e-mail and thanks the site is great. Havent had a chance to look at it in more detail yet though!!
chownr is offline
Old 03-01-2002, 03:25 AM
  #2093
And now for something completely different...
Watch out for binding in the front of the car. The new molds for the Graphite Arms have thicker housing around the hinge pin. When running low roll center blocks the arm can rub on the chassis and cause it to bind. This had me spellbound as I could not determine the cause. The solution is easy enough though...just shave away what you must from the arm to allow for a free range of motion.
Hope this helps, happy racing.
B.
BrianC is offline
Old 03-01-2002, 06:45 AM
  #2094
Thumbs up Low Speed Steering
Thanks guys for your input. I asked Todd Hodge as well from Losi and he said the same thing as what you guys pointed out. Moving out on the shock tower and going to 2 degrees castor. I'll do some R&D this weekend. Thanks again for all the responses.
YokGuy is offline
Old 03-01-2002, 06:49 AM
  #2095
Default 64 pitch???
I need to know what 64 pitch to use for stock carpet and out doors. just got a xxxs so i need some help with set ups .
backmarker is offline
Old 03-01-2002, 06:55 AM
  #2096
Default LRC MOD
BrianC, I had the binding problem you mentioned when going to the LRC with graphite conversion. I had to shave the lower molding of the front arms to free up the suspension. It was good that you mentioned it.
YokGuy is offline
Old 03-01-2002, 09:36 AM
  #2097
Default Re: 64 pitch???
i'm not sure how many teeth it is, but the hot ticket is to go w/ the blue 64 pitch spur and w/ a 2pk2 gear between a 35-37 depending on the layout.
diesel31 is offline
Old 03-01-2002, 10:09 AM
  #2098
CRASH's Avatar
The Blue 64 pitch spur is 128 tooth. A-3954. We gear our P2K2s between 128 and 33-37, depending on track layout.
CRASH is offline
Old 03-01-2002, 01:24 PM
  #2099
R/C Tech Founder
I have a couple revvy P2K2s in my XXX-S, geared at 128/27. I'm as fast an anybody at our track, and my motor comes off the track about 30 degrees cooler.
Plus it sounds like a mod going down the straight.
futureal is offline
Old 03-01-2002, 02:47 PM
  #2100
plan on going to ajs in IL. this sun. and need setups, anything will help.
