SpeedMerchant Rev 6
#181
DPowell in Colorado is a reseller in the USA.
http://www.rctech.net/forum/8061829-post146.html
There is also a reseller in Japan.
Yes, the Rev6 and the Formula 2 front end uses the same Teflon shims. It is important to replace the orings when there is slop between them and the kingpin. There is a new retention mechanism that supports the oring from the bottom with three screws to help it last longer. You can see a pic here :
http://teamspeedmerchant.com/shop/pa...l/smr1650.html
#185
You can still use the same spacer as on the original formula front end. ASC8179.
#186
1s lipo slight swelling binds under shock if I put on a higher ball stud to get clearance putting the shock more horizontal how would this affect handling?the packs perform fine.
#187
Add a shim at both ends to keep the same shock angle.
#193
can some post picture of well balanced electronics layout on a rev6 with a receiver battery? thanks.
#195
Thanks for the fast reply appreciate it.Lance
