Hot Bodies TCX
#4561
Im so bored of waiting for the new car. I get the feeling Tamiya will be getting some of my hard earned cash very soon
#4562
#4563
The TCXX will come with our newly designed 2.5mm narrow main chassis. After tons of testing in R&D, we figured that this chassis covers very wide range of the track condition so we picked this one as kit std chassis.
The solid chassis (almost no cut-out) that you have menioned will also be available as an option item. The thickness of this chassis is 2.25mm which is 0.25mm thiner than kit std chassis but it has way less cut-out, so i would say it is about the same stiffness for the sideway. However, this optional chassis provides less flex front to back. I think it is nice to have both chassis and use whichever the best for the race condition. (which is pretty much what our team is doing)
There are many other new features on the TCXX such as new uuper deck, new motor mount w/rear belt tentioner, Hex shape locking style center pulleys, new sway bars, new suspension blocks,new servo mounts, new longer steering cranks, new shock spring adjusters and retainers, new shock stand-offs, new shock pistons, new steering knuckles and rear hubs, our own new gear diff, etc...
Thanks,
Hiro Kasuya
HB/hpi
Thanks,
Hiro Kasuya
HB/hpi
#4564
Yes, i'm actually entering all the info on the new tcxx setup sheet now. I'm trying to fix the problem on the editable pdf format (can't save the records for some reason) right now but i will post them as soon as they are ready.
Thanks for your patience.
Best regards,
Hiro Kasuya
HB/hpi
#4566
hello Hiro Kasuya sit on the new tcx-x on the following standard parts or option parts low friction shock's body coated titanium shaft's suspension Titanium coated shock shaft's
#4567
QUOTE=Hi-LowBlow;11038853]Hello moraccio,
Best regards,
Hiro Kasuya
HB/hpi[/QUOTE]
Best regards,
Hiro Kasuya
HB/hpi[/QUOTE]
#4568
#4570
yes I want to know if the Ti-nitride shock shafts, hinge pins, and low friction shock bodies come in the kit.
#4571
#4572
I do not see on the new tcxx the Ti-Nitride shock shafts, hinge pins, and low friction shock bodies come in the kit.
#4573
No, they won't be in the TCXX kit. But we have very much confidence with the kit standard spec so you should be happy with all the parts come with the kit.
Thank you.
Hiro Kasuya
HB/hpi
#4574
No problem, I buy them anyway
#4575
Hi all,
Team HB's world setups! (From Teemu, Shin and Hara)
I will post Andy's later.
