Hot Bodies TCX
#2926
Pics of the battery stopper mod. All of this was done with Pro4 servo mounts and the fan was done with TA02 servo mounts. The fan mount allows tilt and angle adjustment and if needed, fans can be split so one blows on the motor and one on the esc.
The battery has been moved so far that I had to use a soldering iron to melt part of the battery strap so the corally plug could go through! Like David Galdo said, the car is pretty much balanced when the battery is this close to the centreline of the car (assuming you are using the newer heavy Lipos like the 5500-6200). If you are using older batteries like 5000, the car is already pretty balanced in the standard position as the battery is only about 265g heavy.
#2927
I am not doing anything special and definitely not adding more than is needed. I made a couple stoppers that slide under the belt and use the available screw holes on the chassis. There is a screw hole just before the motor mount and the other I am using is the same for the antenna. As seen in the picture I am using servo mounts and tape. That's all it really needs. I have never had the pack come out nor does it have much movement left and right.
#2928
#2929
Gear diff oils
Hi guys,
I'm currently running the spec r gear diff in the rear of my tcx. Im racing indoors on carpet using Fastrax 1000 oil. I was just wondering what are the cars handling characteristics of using a slightly thinner or thicker oil?
#2930
Hello
Someone can tell me what is the internal measure in mm between the Hot Bodies TCX lower Bulk Heads.
Because I wanted to buy a differential of Hot Bodies and wanted to know this measure to see if it fits in my car.
Thanks in advance.
Best regards:
Pedro Silva
Thanks in advance.
Best regards:
Pedro Silva
#2931
Driveshaft blades
Has anyone had trouble with the gear diffs destroying the driveshaft blades?
If so, any ideas on how to stop this?
#2933
Who's blades are you using?? I had a pair of Top blades that came with the steel axles Dumas gave me so I worked on them a bit to fit the Spec-R. I have noticed little wear. Had them in for a few weeks now with 42 or so packs on them. When they wear though I will transition to the TC6 blades I bought, they are a perfect fit for the Spec-R.
#2935
#2936
#2938
kit items
hey guys just ordered a tcx kit,can't wait to get it but,.... i have a few questions on what option parts come with the kit,so if there is something it dosen't come with i can order it now! does it come like previous kits with a spool and a one way or a diff for the front? does it come with aluminum or steel cvd's in the front? by reading around i hear that it does come with a full set of different swaybars,and i have a crap load of cyclone tuning parts as well =springs, pistons,ect,so far i have ordered a spec-r gear diff,front steel dcvd's,exotec chasse,titanium shock shafts&susp.shafts,i don't want to come up short on the build!
#2939
The Tcx comes with a spool up front and a ball diff in the rear. I have Tamiya 3 hole 1.1mm pistons in my shocks. I would recommend changing the front bones to the Pro D 46mm ones for strength. These seem to only be available from Hong Kong. Once you have the Pro D bones fitted the spool outdrives become the next weak point, I have a Roche spool ready to fit in mine which I'm going to run with T O P Photon bones as the Roche spool outdrives slots are too narrow to take the Pro D bones. Apart from a few shims here and there that's it. Enjoy!
#2940
