Hot Bodies TCX
Old 03-11-2011, 03:10 PM
  #2386
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Matt W
Thanks Antoni,
Here is my current setup......
I run on a very grippy open carpet track and the car is very snatchy on the front end and very nearly grip rolls on corner entry after quick directional change......
2 degree ff and fr toe blocks
1mm under all toe blocks
4mm under all upper camber links
Front wheelbase, 2.75 front, 1mm rear
Rear wheelbase, 2 front, .75 rear
Rear hub, .75 front, 2 rear
4mm akerman
Front toe, 0
Rear toe, 3
Front camber- 1.5
Rear camber- 2
500 weight oil front
400 weight oil rear
1mm 3 hole pistons
Hpi Gold and silver springs
Front shock position, 1 on wishbone, 4 on tower
Rear shock position, 3 on wishbone 5 on tower
Front droop, 6
Rear droop, 5
1.4 front roll bar
1.2 rear roll bar
5mm ride height all round
I also glue the front tyre edge to help with grip roll......
Any thoughts?????
I would test between the 1mm and 1.5mm under the rear blocks to see what you like, a pink front spring as suggested, maybe even pink all round. Definatly change to a 1.1 3 hole piston and go back to 2mm under the camberlinks. But what i would try first is shock positions, try going back to the kit holes on the arms, maybe try the rear first, and go to hole pos 3 front, 4 rear on towers. If you still have issues try 2 front, 3 rear. That will take away a lot of the initial bite.
And if you still have traction roll after all of that, try 7-6 droop.
Hope something there will cure your problem
Antoni
Yokomo_Ant3 is offline
Old 03-11-2011, 07:06 PM
  #2387
tha Beast's Avatar
Trader Rating: 100 (99%+)
i havent seen much talk about the Exotek txx chassis for the TCX has anyone tried it out and got any feedback im thinking of getting one but i want to make sure its worth it first
tha Beast is offline
Old 03-11-2011, 08:12 PM
  #2388
jag88's Avatar
... that and the Smokem chassis.
jag88 is offline
Old 03-11-2011, 08:34 PM
  #2389
b_recliner's Avatar
Trader Rating: 22 (100%+)
I'm awful curious about the exotek myself . Any information would be appreciated gentlemen.
b_recliner is offline
Old 03-12-2011, 06:40 PM
  #2390
M3Armand's Avatar
Default Aftermarket Suspension Arms
Are there any alternatives to the stock suspension arms part number 67717?
I had 3 of these as spares and in less than 3 hours of running, I managed to break all of them. I can't believe how brittle these TCX suspension arms (and hubs) are. I'm seriously disappointed. Before anyone says "stop hitting walls", yes you are right. But I've been running my RS4 Pro for 14 years and have not broken any suspension parts yet! Just as a data point, I used my RS4 Pro for the remainder of the day for another 3 hours with no broken pieces...
I know there's a supposed to be a HPI High Traction Suspension Arm Set 31420 that's a little "softer". But they are never in stock. So for all intents and purposes, they don't exist.
Any other after market ones out there?
M3Armand is offline
Old 03-12-2011, 06:46 PM
  #2391
Mike Haynes's Avatar
I have run both chassis on my cars on carpet now. Either one is for sure an upgrade from stock, they are both nice and narrow, and have the battery moved in with no extra work. The smokem chassis flexes more then the exotek, depending on what your looking for you can make the choice. I'l be running outside real soon so i'm not to sure just yet which will run better there. I have a bit of a fear of my battery flying out so my preference is the exotek untill smokem adds some retainers.
Mike Haynes is offline
Old 03-12-2011, 07:31 PM
  #2392
David Galdo's Avatar
Trader Rating: 15 (100%+)
Hey, stop hitting things...
Use the 73506 arms. To me they seem a bit softer than the originals and are stronger. I see they are available online: http://hotbodiesonline.com/products/en/73506.html
David Galdo is offline
Old 03-12-2011, 08:12 PM
  #2393
KHoff7's Avatar
Do you have to "sand" the edges on these?
KHoff7 is offline
Old 03-12-2011, 08:32 PM
  #2394
Jerry P's Avatar
Trader Rating: 44 (100%+)
You're but he probably did already.
Jerry P is offline
Old 03-12-2011, 10:03 PM
  #2395
CL
CL's Avatar
Trader Rating: 34 (100%+)
The Tamiya short arms like the ones on the 416 & 417 also fit.
CL is offline
Old 03-13-2011, 07:18 AM
  #2396
M3Armand's Avatar
Does this have the exact same geometry as the originals?
Do you have the part number and does this have the exact same geometry as the originals?
Thanks guys...
M3Armand is offline
Old 03-13-2011, 07:50 AM
  #2397
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
sanding carbon edges is overrated.
hanulec is offline
Old 03-13-2011, 07:51 AM
  #2398
SammyZ's Avatar
Trader Rating: 138 (100%+)
i have a Cyclone WCE andy moore edition in good shape,
lots of hopups for your TCX!! PM me!
SammyZ is offline
Old 03-13-2011, 07:53 AM
  #2399
stuey's Avatar
Thanks guys...
tamiya ones no diferent geometry orignal not sure probably not or why change them.
stu
stuey is offline
Old 03-13-2011, 08:10 AM
  #2400
If I remember correctly, the 73506 make a slightly shorter wheelbase in the front. Despite, the geometry remains the same.
quick-nik is offline
