BMI Racing "Copperhead 12" discussion and support
#272
Yup...and only the non-ROAR WGT. ROAR has their own rules for WGT that also does not include a sliding king pin rule. If that rule were in place the old HPI Road Star never would have been ROAR legal as that also used a double wishbone type front suspension. That was a cool suspension but had a couple mistakes in the design that should have been remedied before going to production.
#273
Ah okay, well... Luckily I drive Pro10 and there we can use whatever we want...
#274
hey guys...
...a question about running the servo laid down. I just noticed that the turnbuckles are slanted downward towards the steering arms. Do I use taller ballstuds/space these up to have the turnbuckles parallel to the ground/chassis? And why, if I may ask? Or does it even matter?
#275
Trader Rating: 51 (100%+)
Hey Jaybee,
Yes you want to add a Med Ball Stud to the steering arms when you have a laid down servo setup. The reason why is it reduces bump steer. You can get the Med Ball stud from IRS racing and I think BMI has some on there site
Hope this helps
Mike
Hope this helps
Mike
#277
#280
I do not mind paying more for the car . But I have a problem with having to buy two front ends with my kit, when I know I'm not going to use the Associated style front end. I'm confident many others agree with me .
#281
So, there will be an option to buy the Copperhead with the new suspension, but the cost will be higher than the Copperhead with the old Associated style front end, correct?
#284
Hey Jaybee,
I'll Try to answer these as best as i can
Part# DB1030R The difference between this part and the original is that it sets the shock back on the top pod it changes the leverage of the shock. I helps make the car rotate better.
Whats a nice feature on the DB12RR and the new Copper Head12 car is you can position the shock mount forward or back. It changes leverage on the pod and how much traction or less traction you want. So if you want more traction move the mount forward and if you want less traction move it to the rear.
Part# DB1020R This is different than the original this lengthens the car some it basically keeps the car more stable and I think a longer wheel base helps the car carry more corner speed I have to ask Jason on this.
Part# DB1041R this part is for the DB12RR car its pretty much like the original but its made for the DB12RR
Part#DB1053R Is the pod brace for the DB12RR car on this car the pod is a little wider to allow more room for brushless motors.
As for 1c lipo's there's many alot of people are using Thunder Power, Trinity just to name a few.
Hope this helps
Mike
Hope this helps
Mike
