Schumacher Corner
R/C Tech Elite Member
You tell em Randy (how about we push those that make me work in the pool at the hotel this weekend)
Skiddins - I think I remember 276 Grams, so yeah....right there somewhere
Patrick - Between the Core and TIR, I have no idea what the weight difference is.
And for the record my lap dog pwns, I inherited her from my mommy when she passed So my lap dog rocks your particular socks and such
Starling, you came creeping in here like you own a different car or something...what gives my man??
To all, email me if needed, Snowbirds prep this week and were gonna be busy beavers!
http://nexusracing.net/product_info....roducts_id=890
But get on it, cause they're usually sold out (they move FAST)
Super Moderator
My friend showed me a little trick for the core 5000 pack, he went to Ace Hardware and found a metal strip about a foot long that is the same width as the battery slots in the chassis , all you have to do is cut to the exact lenght, then glue them to the bottom of the pack and the fit very well. the bar is just under 2mm thick. The metal bar is gold color , im heading to Ace tomorow and see if i can find it Each strip weights almost 10grams each if i recall.
Super Moderator
That looks like brass. Thats a great idea Marco. It gets weight on the car and does it really low.
FYI....
Schumacher Corner is ranked 2ns in Electric On Road for most replies. The 1/12th is first.
Schuamcher Corner is ranked 3rd in views with just over 750,000 views. The 415 thread is second and the 1/12th thread is first with 1.125 million views.
WOW!
WOW!
If I were to use Tungsten alloy I have calculated that the max sixe I can fit under the Orion 3200 LIPO is 181 grams (without using the battery slot openings)...I am still almost 50 grams lite. This sucks...looks like I will need to buy 4600's for the Nats!
Weight in LIPO has got to be a consideration at least for on-road touring cars. Off-road it is easy to make weight and keep car in balance.
Still pondering my options at this point!
I like the idea, but unfortunatly that will not work for any ROAR sanctioned event. The weight must be secured to the chassis and not the battery in any way. I have been working overtime on this one and still have not figured out a nice way to make weight. Trying to keep the weight as low and as central to the battery position is difficult.
Registered User
Thank you for the fast info on LW items,but can someone really tell me what difference this will make to my car
I am a club racer hoping to run a couple UK Nationals but I generally run 10.5 Brushless with 6 Cell indoor rubber on carpet currently my car is way off the weight limit according to BRCA rules
Weight differences;
LW Bulkheads – 28 Grams
U3255
Droop screws 1.3 Grams
U3261
Ball Studs – 6.6 Grams
CR021
Screw Kits – 17.7 Grams (breakdown below)
CR010
M3 x 20 Button head Screws – 5.6 Grams
M3 x 16 Button head Screws – 4.3 Grams
M3 x 10 Button head Screws – 2.0 Grams
M3 x 12 Countersunk Screws – 2.5
M3 x 10 Countersunk Screws – 1.7
M3 x 8 Countersunk Screws – 1.6
Shock Posts – 2.25 Grams
U3260
Lay shaft - 1.7 Grams
U3262
Ti Inner Pin 55mm x4 – 5.5 Grams
U3169
Ti Outer Frt Pin 18mm x2 – 1 Gram
U2719
Ti Outer Rear Pin 25mm x2 - 1.46
U1576
35mm Turnbuckle – 3.6 Grams
U1905
39mm Turnbuckle – 2.0 Grams
U1572
Once again thanks for everyones input
Weight differences;
U3255
U3261
CR021
CR010
U3260
U3262
U3169
U2719
U1576
U1905
U1572
what i am about to say should be thought about before YOU attempt it,
if you camfer the battery slots pretty good, lay the chassis on a piece of glass, clean your lead strips really good, melt it, pour it into the battery slots, then it would be "in" the chassis and not attacted to the battery.
wearing the proper protective gear would be a must when doing this.
How about I just send you mine
Super Moderator
I think what roar means is that it can be attach like with velcro, so is not easily taken off, i think shoegoo is almost as good as screwing the weight in.
Super Moderator
