Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-18-2007, 04:22 PM
  #20866
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Randy Caster
Also, for anyone having problems with wheel nuts coming loose, order Hot Bodies part #61092 I have been running the same 4 nuts since the RROC and havent had a single one loosen up one bit.
Or try 'blue threadlock'
.........Nice meeting you Randy and I thought your car looked pretty damn good. Nice driving dood
JayBee is offline
Old 07-18-2007, 04:27 PM
  #20867
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Be careful using thread lock on your wheel nuts. I've seen it react strange with some wheels and weaken the center and cause them to break.
Jon Kerr is offline
Old 07-18-2007, 04:29 PM
  #20868
The wheel nut problem has been there since the early missions. Just buy some cheap ones at the local hardware store, they'll do the job. They aint pruple though...
And no, the Hot Bodies ones dosen't work either...5 times of screwing on/unscrewing and the RF fell off.
Jan Larsen is offline
Old 07-18-2007, 04:32 PM
  #20869
JayBee's Avatar
Weird Okay I retract my suggestion LOL...I don't wanna be the blame for that.
JayBee is offline
Old 07-18-2007, 04:38 PM
  #20870
Jon Kerr's Avatar
I'm not saying it will happen for sure. I used to use that trick all the time, then, I think it was on the older hard RP wheels when we first started using them, I had the center break out of a wheel on one of the first runs. I looked at the others and there were stress marks on the wheel under the wheel nut. I tried not using thread lock after that and never had another problem.
Jon Kerr is offline
Old 07-18-2007, 05:03 PM
  #20871
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
I've been using the same Hotbodies wheel nuts on my cars for 5 months with no problems. I take my wheels off after every run. After this long it still hard to get them off. Don't belive the hype
L.Fairtrace is offline
Old 07-18-2007, 05:11 PM
  #20872
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Trust me, that part # that I gave you will not fall off. It's not a locknut, it's a serrated nut, no nylon to wear out.
Randy Caster is offline
Old 07-18-2007, 05:16 PM
  #20873
Nice meeting you too JayBee, hope to see you at some races in the future.
Old 07-18-2007, 05:21 PM
  #20874
I know, staring at it right now on the shelf
Could've been the wheel though, Take Off wheels are known to be on the scruffy side (thank GOD i dont have to run their tires anymore!)
Old 07-18-2007, 05:25 PM
  #20875
haha, guess ya gotta crank it down harder next time!
Old 07-18-2007, 06:45 PM
  #20876
PW
PW's Avatar
Originally Posted by qwkpony
Yes, running a spool. I'm already at 3 degrees rear toe. 2 degrees inboard, one degree outboard.
This is one of your oversteer problems. Go back to 0deg rear hubs and put all 3deg toe in the hinge-pins.
The Parma M body will also lock in your car
PW is offline
Old 07-18-2007, 09:26 PM
  #20877
Trader Rating: 19 (100%+)
For a asphault one way set up on a huge track. i know more rear tow and mabe more caster anything else thanks
teammidget lilB is offline
Old 07-18-2007, 09:44 PM
  #20878
JayBee's Avatar
For anyone running Novak brushless, what's a good FDR for a 10.5SS with a 114t spur...tight indoor asphalt track BTW
JayBee is offline
Old 07-18-2007, 09:53 PM
  #20879
skypilot's Avatar
Trader Rating: 14 (100%+)
i'll be running on a large outdoor track this sunday, i'll be using the same setup as at nats with the one way, i'll let you know how it works.
skypilot is offline
Old 07-18-2007, 09:55 PM
  #20880
skypilot's Avatar
we gear the 13.5 to a 5.2, what ever the instructions say for the 13.5 convert it to the instructions for the 10.5, i'll be there friday night to help.
skypilot is offline
