Schumacher Corner
Tonight is the first test run of my new MI3. I drove it real quick at work and it feels good. I can't wait.
Sorry about the muddy details LOL....
The track is small/tight w/ some tight chicanes and a 40-50ft straight. The carpet is really starting to catch a groove so bite is pretty darn good. My Parma Pro 53's are 57.5mm; using Magenta/Magenta but last raceday I really dug the Indigo/Magenta set-up. Motor is CO27 w/F's and purple/red springs....
R/C Tech Elite Member
I ran quite a bit of droop, actually really similar to those settings.
I've been getting a lot of PM's with suggestions and such, so I have a lot to try out if I cant get my cars working good for Vegas.
I almost have my 19t car done, I'll have to shoot some pics when I get everything together, kinda went a little overboard on making stuff look cool
Tech Legend
Trader Rating: 51 (100%+)
barger/abailey: thanks! speedtech and schumacher-rc are great! thanks for the links! very big help.
another question guys (hope you dont mind), i run 64pitch gears and if i decide to get the mi3, i plan to switch the stock spur to 64pitch. after searching for 64 pitch spur gears, i found these in the schumacher-rc site ....
U3164 - 116T 64DP Spur Gear
U3133 - 114T 64DP Spur Gear
Just want to be sure these are the ones for the mi3 since it uses special/custom spurs. The description does not specify if these are for the mi3. Hope you can help. Thanks again!
64p 114 tooth - U3163
64p 116 tooth - U3164
64p 118 tooth - U3165
64p 96 tooth - U3248
Ok, shipment is in, we have back in stock
Med flex frt/rear arms back in (U3249, U3250)
2.5 Carpet Top Deck U3246
Overdrive Pulley's;
Spool - U3253
One Way - U3254
We should have most of the new Core Titanium screw sets and parts in next Thurs, (09-27-07)
Still waiting on Alloy Rear hubs, Lightweight Bulkheads, i'll let you know the minute they hit the backdoor!
Overdrive Pulley's;
Spool - U3253
One Way - U3254
Hey folks. Anyone have a rubber tire setup for the MI3? There is probably one posted on here somewhere, but im waaaaaaaaaay too lazy to search for it
