Xray T1
#6871
Originally posted by new92
The outside of the bulkhead? I thought they went between that holder and the bulkhead. Hmmm, I may have done my wrong....
#6872
Originally posted by dontfeelcold
I was wondering what the biggest size spur gear (48 and 64 pitch) people are using with the low ratio in modified as i am going to make a spur gear cover so I dont get anymore rocks stuck in my spur gears and pinions and I need to know the diameter of the spurs so they dont hit the cover. this will make it like offroad cars will the fully enclosed spur and pinion.
64dp - 128t
#6873
Hi all...What is the difference between the Evo2 and the FK?
Thanks!
Thanks!
#6874
-New lighter bulkheads
-Low ratio pulley
-Front one-way
-Center solid shaft
-Euro arms (shorter arms)
Cant remember the rest.
Overall, a lighter and better (??) version of the FOC
-Low ratio pulley
-Front one-way
-Center solid shaft
#6875
-Low ratio pulley
-Front one-way
-Center solid shaft
-Low ratio pulley
-Front one-way
-Center solid shaft
- lightened dogbones
- lightened axles
- lightened solid centre layshaft
- lightened 1 way outdrives
- new front/rear shock tower
- solid upper deck
#6876
It is so light, its hard to reach legal weight during the race.
Hahahaha
Hahahaha
#6877
Trader Rating: 22 (100%+)
I hads to add 70 odd grams to the car to make it a legal weight. Take all the weight off and it's really reactive.
#6878
Hahahaha
Hahahaha
#6880
Originally posted by evaa
i just got an xray evo 2 foc, was wondering if i could use ae or losi springs? tanx guys.
#6881
Originally posted by sands
The Factory team kit has short arms - they need to be mounted on the outside of the bulkheads.
Oh, ok thanks. I am using the T1R...was scared there for a second lol.
#6882
Couple Questions:
Does the Ft Kit come w/ Sway bars????
What should i buy addition to Ft Xray?
#6884
what's the smallest spur gear that fits the xray??? (by rising up the motor, the belts can touch the can)
#6885
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Originally posted by True R/C Racing
Couple Questions:
Couple Questions:
Probably just need springs and 2mm swa bars front and rear if u don't already have from Evo2.
