Xray T1
#3811
i am going to be geting my evo2 in a few days and was wondering what spares to get? Also can someone post a good setup to start with im going to be using cs-27 take offs.
#3812
#3813
jiggamacdaddy: See if you and your Dad can come down to the TQ state race next month it would be fun for you guys and I can help you out with the EVO. We have got'n everione to switch to Xray at TQ. We now have about 15 guys runing the Xray. Go to www.fseara.com or www.tqhobbies.com for more info. Oh and tell your dad I said what's up.
#3814
hey pucho im coming down for the state race for my bday. i was wondering if you could give me a good setup to start with on cs 27s. also im geting a one way with it and was wondering if i sould use it?
#3815
This is my set up at TQ with a one way, my set up for Superior I posted a few post back.
Front:
Blue springs
30Wt oil
3 hole fixed piston/2 hole if you use adjustable
standard shock mounting position
standard camber link position
0deg kick up
3deg caster block/6 deg if you need more on power stering
1deg camber
0deg tow
4.5mm ride heith
one way
Rear:
Blue springs
30wt oil
camber link on inner bottom hole on bridge/inner hole on hub
0 anti squat
2deg tow
1.5deg camber
5mm ride heith
diff set loose
Geared with a monster stock at about 7.80 (short track)
proto stratus 2.0
Hit me up if you need any advice on building the car. BTW other than the one way get the roll center bridge, and spring set ( the basic will do)
Front:
Blue springs
30Wt oil
0deg kick up
1deg camber
0deg tow
4.5mm ride heith
one way
Rear:
Blue springs
30wt oil
0 anti squat
2deg tow
1.5deg camber
5mm ride heith
diff set loose
proto stratus 2.0
#3817
cool thanks man i was wondering if some people where using the racer chasis for racing on asphalt insted of the graphite one?
#3818
Observation......
I ran my T1r for the first time today and must say I am very pleased.This car is so nice and consistant from lap to lap its not funny.All I can say is for the first time running it outdoors today was a real pleasure.With the 1.77 ratio pullies,it was as if there was no advantage for SHAFT cars....and believe me, I owned all of them.The car turns in so well and carries ridiculous corner speed I was in shock.Easy to drive,well for some that drove it they didnt think so.But for me,its a perfect fit.I turned more then a few Tamiya owners heads.You should have heard the race announcer mocking me because I was driving the "Ugly budget Xray car."Noone was mocking me after the A main. Thanks again guys for the setup help.Used the setup posted here for asphalt....Puchos setup......Dialed.
#3820
xxxkat: TQ hobbies has them in stock plus they are an RCtech supporter. Drop them an email or give them a call they have both in stock. www.tqhobbies.com
jiggamacdaddy: I would actually recomend for you to save some cash get the T1R it's absolutely great.
racenut123: Glad I could help.
#3822
Originally posted by xxxkat
Have you been to this site ? I saw no place where you can buy parts or see a list of parts,looks nice but once again i will have to keep looking to find them darn parts,thanks anyway
#3824
Unfortufnately they don't have a shopping cart but this is my LHS and I help them with the orderign unless they sold this week end they have them in stock and they will shipp them.
#3825
Hey guys, in your opinion, what are the best pinions on the market? I was thinking about buying a complete set of XRay pinions, however XRay makes two types, Steel and Aluminum Hard Coated. Which one is better? The Aluminum Hard Coated pinions sound better as far as the description goes, but the steel ones are more expensive.
What do you guys think? I would really like to know what people who have used both types think.
