Silver Can versus 21.5 Brushless
Anybody know how closely matched a typical silver can motor is to a 21.5 brushless? I'm currently running silver can in one of our local classes but am thinking of going brushless (at this point, merely for maintenance (or lack thereof)). But I'm hesitant if it won't allow me to be as competitive (yes, the class rules allow the use of either).
Also, is there a good 21.5 brushless that works sensorless. I currently have a Mamba Max ESC and would like to continue to use that so I don't have to drop money on a new ESC as well (though it's in my future plans to get a great sensored ESC)? Would the Duo/Duo2 work with me and my Mamba Max?
Thanks all!
Thanks all!
hi,
a 21.5 walks all over the 540 by about a second a lap. over here we have done lots of testing on this matter, and there is no way a 540 can keep up. if you have rules that allow both, the pack should be split right down the middle...
cheers
cheers
Thanks all!
Thanks all!
Originally Posted by Pablo Diablo
NO! sensorless only works with low turns motors. Even a 10.5 will struggle to run well sensorless. A 21.5 on a sensorless speedo would be asking for trouble.
I know what you mean. The new speedo will make anything come alive! From what I saw last year with motors was a Speed Passion 21.5 vs a Novak 21.5 day and night difference. The Speed Passion had a lot of rip!
If it comes down to make the people with the new speedo's change there settings to the first profiles. Rob King has been testing this for the USVTA.
I would love to see a 21.5 Sedan class.
Dave
Dave
Dave
Dave
I've got two set-up's
1/ LRP Sphere with LRP motor... which with the right rollout no one passes on the straight
2/ Tekin RS with Tekin motor which at our home track has passed 17.5's on the straight..."Woohoo"
I'm for not placing restrictions on motor/esc or rollout for this class...
We run it as a TC class
Seriously though,once you go brushless, you'll never use brushed again.
Just charge and go !
The 21.5 is very tractable power. The looser the track ,the closer to 17.5 imho.
I use an SPX and Novak, but will look to getting a Duo 2 in the future.
Buy one DECENT lipo, recharge between rounds. Two cheap lipo packs are no substitute.
I like the Intellect cells best.
Hobbycity Lipos are no longer on the list of "budget" packs. They simply do not overcharge for the same products. They do have a few products that have poor history, but they do not hide it on the site. Its easy to read the reviews before making a purchase and know you are getting a quality product. On the other hand some companies are STILL charging 3 times as much for customer service, while over and over you see useless packs still showing up.
Check with CC about running the 21.5 on your Mamba Max, I know many of the updates are just for this reason. I have never used more than a 17.5, but I had trouble with older firmware, and great luck with the later versions.
Don't waste time with a sensorless esc. Once you gear up to be competitive ,
It will cog like crazy , and IF it gets off the mark, you will encounter rotor slip on corner exit.
I have tried !!
As for Hobby City gear, it has its place,just not in RACE cars.
I own some of their lipo packs and they DON'T compare. Sorry.
I have tried !!
