Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#392
The Hotbodies Nissan has more downforce everywhere but there are markings front and back to cut out of the body so you can tailor it for less downforce.
#393
Moderator
Use 0.018" if you need more steering, 0.022" if you want to kill some steering.
Using the above, keep in mind that a firmer spring gives a bit more initial steering (faster response). Oppositely, a soft spring can give a bit smoother steering.
#394
#395
http://www.youtube.com/abrampl#p/u/19/OfmxyPfT_dU
#396
Good idea but most saddlepacks are flat underneath. That stickpack has bumps underneath that fall in the slots. Not sure if a flat lipo will stay on the chassis without anything in the slots.
#397
Thanks so much for the info guys, very helpful.
The reason I'm putting this car together is because I had a drive of a modified TC not too long ago, it was fast but I told my friend who owns it a pan would beat it with the same motor! My friend took the challenge, he constantly goes on about how pan cars are 70s technology and have no hope against a TC! Anyway, building this car to show him otherwise! I might not beat him but I will put up a fight! TCs just look so overcomplicated! I understand they are good for rougher tracks but our local tracks are very smooth.
#398
Overhere at almost every race we race, we meet or beat the TC modified guys. They are all driving with motors in the 4.5 ranges and we drive a 10.5!!!
At most races we make the same ór faster laptimes than they do so... Pancars RULE!!!
#399
my Corally 10SL is usually 0.5sec quicker every 10 seconds then modified 4WD cars..
#400
Hi, I watched the tutorials on youtube. Any chance for an English version?
#401
#404
All depends on track lenght,open track,tech track,type of motor(brand) and so on.
To determine a rollout or gearing you need to consider more then just the motor and if it is boosted or not.
For example.
At our track if we run blinky(non timing) we use a FDR of 4.0 with 13.5 motors in TC stock.
If we run with timing,boost and turbo, it can come as high as 7.9.
This with the same brand of motor.
Pro10 is the same.
If your running a Tekin motor with timing, you have to let it run at higher rpm's then for example a GM or LRP motor.
This because the Tekin has less torq then the other 2 mentioned motors
Are you running on a nitro track? or a small track?
regards Roy
For example.
Pro10 is the same.
regards Roy
#405
Mostly I run an 81 spur (48dp) and then I fix the roll-out with the pinions and tire size. On a large track like Heemstede Holland I run about 37mm roll-out with a HW ESC and a GM of Trinity motor.
