Like Tree65Likes
TC3 Forum
Old 01-16-2006, 09:23 PM
  #10861
Tyson's Avatar
rockdog, you can get one at a hobby shop for like 60-75 dollars. which is rediculous. i would get it off another buddy from your local track. or from ebay maybe.
Tyson is offline
Old 01-20-2006, 06:28 PM
  #10862
Hi
I have got a TC3 RTR,,,,I have fitted the Blue Alloy Threaded Shocks to it but kept the stock springs on there (Silver and Gold) with 40wt oil....
I race indoors on carpet but am having real problems with understeer,,, it wont hold its line in a corner unless I come right off the power..
The back doesnt step out or anything its just the front end thats got hardly any grip....
I am not running any anti roll bars or anything but I have got a full set of different colour springs coming,,,, I am also using CS-22's which most of the lads are where I race and they have no problems and we all use the same tyre traction liquid too
I would be grateful for any help and advice..
Cheers
Stu
RompingDonkey is offline
Old 01-20-2006, 07:05 PM
  #10863
graphiteman's Avatar
On a high-traction surface, you may want to use firmer springs. I use the red springs on all 4 corners, and although not carpet, I run on very high traction asphalt. I would suggest checking your servo saver mechanism (hole through the bottom of chassis that can tighten the screw/spring tension to the steering linkage) to make sure it has not backed out. I found this to be a problem with mine. There are good setups that might help you here:
http://www.rc10.com/racerhub/setup/0setups_onroad.htm
The differential settings can make a huge difference too, so play with them a little. Go tighter on the front, less in back and see what happens. I use a one-way now, but did have the car handling well with the diffs before changing.
Check your droop settings, as this is where you can make significant changes to the handling of your car. Compare them with the setups on the link. If you dont have a droop tool, get one of the Team Associated parts for less than $8.00..... its a must have!
graphiteman is offline
Old 01-28-2006, 10:09 PM
  #10864
ScottyP's Avatar
Just picked up a used one-way for my TC3, but on trying to fit, it appears to be too wide. When I fit the bearings and try to slide it in the housing the bearings sit wide of the grooves in the housing.
I'm thinking maybe I've got the wrong part. Any clues?
Cheers,
Scotty P.
ScottyP is offline
Old 01-28-2006, 11:15 PM
  #10865
You have to change your springs. I had the same thing, a TC3 RTR and the springs it came with. Those are fine for running it out in front of your house but anything else you need to get springs.
I used Mike Blackstocks carpet set up for the "Birds"
http://www.teamassociated.com/racerh...birds_2004.pdf
I used this as a "starting point". But just changing out the oil and springs as made a world of difference.
Hope that helps. Good luck.
wcalaker is offline
Old 01-28-2006, 11:32 PM
  #10866
csdspeed's Avatar
Can the differential of the tc4 be used on the tc3? My rear long hub of my differential in my tc3 broke. It's harder to find tc3 parts these days so I need to know if the tc4's parts can be used. Thanks.
csdspeed is offline
Old 01-29-2006, 12:17 AM
  #10867
Aries326's Avatar
Trader Rating: 19 (100%+)
Sounds like you got a one-way that isn't for the TC3. PM me your email address and I'll send you a pic of what my TC3's one-way looks like.
Henry
Cheers,
Scotty P.
Aries326 is offline
Old 01-29-2006, 09:00 AM
  #10868
PaZ
PaZ's Avatar
TC4 diff parts fit the TC3 im using the lightweight steel TC4 diff halves there great
PaZ is offline
Old 01-29-2006, 09:35 AM
  #10869
newera152's Avatar
What brand are you using? Ive asked many people that sell the TC4 Diff if they would fit the TC3 and they say no.
newera152 is offline
Old 01-29-2006, 10:25 AM
  #10870
PaZ
PaZ's Avatar
associated's own TC4 lightweight steel diffs there the same size diameter they are a slighty different design in as they are not all flat they have small groves cut out maybe to save weight? Part number AS31062 heres a pic i got em front and rear with the TC3 gears and there perfect
PaZ is offline
Old 01-30-2006, 08:25 PM
  #10871
Default Shocks
All you touring car guys - I just rebuilt my shocks with the new Associated VCS shock upgrade kit - the bladders have arrived - best shock design improvement by Team Associated yet - this makes a world class touring car shock. Team AE does it again!!!!!!!!!!!!!!
DLM2005 is offline
Old 01-31-2006, 01:54 PM
  #10872
Aries326's Avatar
Got a part number for it? I may need a rebuild later this summer. Thanks!
Aries326 is offline
Old 01-31-2006, 03:45 PM
  #10873
#31123 VCS shock upgrage kit $16.99 - If I were you I would spend the $16.99 and upgrade them now - you will be glad you did - it sort of like going from bushings to ceramic bearings...
DLM2005 is offline
Old 01-31-2006, 04:08 PM
  #10874
Aries326's Avatar
Wow, that good? If you put it that way, maybe I will try them out. How do they compare to Yokomo SSS shocks? Thanks for the part number!
Aries326 is offline
Old 01-31-2006, 05:21 PM
  #10875
Well it rebuilds the Associated VCS shock with bladders with no need for bleeding the shock - the build on all shocks is very consistent ( I've built 8 shocks so far) and they all are very smooth - an automatic perfect build.
DLM2005 is offline
