The Speed Passion Thread
Reventon pro and blaze 550 5700kv test
Tested my Reventon pro and blaze 550 5700kv motor in my Tekno 410sct Sunday. Reventon was set to stock 0. dsr 2 break force 80% drag break 10%. temp off. vot off. two 10 min practice runs. Three heats. one main TQ and Win. ESC worked great The truck was a land missile. Truck was geared 12 p stock spur. ESC temp was 145 at end of run motor 125. Can Anyone or is anyone in touch with the Speed Passion Team Rep? Is it still Albert? I have been geting my stuff from Schumacher and have lost contact with the team manager. I need some speed Passion sticker sheets. i have emailed SP USA with no reply's twice. PM me Please Thanks.
Wfi Module
I am having a problem with a brand new Wifi Module, it won't stay connected with the iOS device, i have tried reseting the module but does not change.
Any help would be appreciated.
thanks terry
Edit: got it to point that I can connect to the iOS device and connect to the App, but does not get any Data from the ESC. Tried three different cables between the ESC and Module.
thanks terry
I bought the 17.5 MMM motor and it arrived at the end of February but I've been having some problems with it. When I accelerate it kind of bogs and hesitates a bit before it gets going. I also noticed it's not any faster than my old Speed Passion motor that had no timing adjustment on it. I thought it was the sensor cable so I ordered a new one and tried that but I still got the same problem. I'm using a Reventon Pro with this motor too to replace the old Citrix ESC I was using before. So I took out the sensor board and did a bit of troubleshooting with a multimeter to test the connections and I noticed that there are two empty solder pads. It looks like a capacitor or resistor should go there but I"m not sure. Can anyone confirm if my sensor board is missing a component in the area I have circled in red?
Whats the speed control BEC power rating? servo? I had a similar problem and found out it was my speed controls BEC. The BEC wasn't strong enough to power my high speed servo and motor properly. All I needed to do i buy a extra power cap and plugged it into my receiver. Problem solved.
You can do a quick test and see if that is the problem. Put your car on a stand, turn it on, give the motor some throttle and check if its bogging. If its not then the next step would be - give the motor throttle and move the servo left and right fairly quickly. If its starts to bog or cog then its your BEC.
Hope this helps.
thanks terry
thanks terry
I dont have a Program Card, just the Module.
The ESC does work when hooked directly to the Receiver, just can't make any adjustments through the Module.
The App does show the ESC connection as being ON as it is highlighted in green, but when press the OFF button nothing changes. And the App keeps asking me to connect the ESC.
Thanks WMGary, the idea of buying the Wifi Module was to eliminate the need for a program card, and having to use a PC. I don't own a PC, just Apple, so the Program card would be useless to me.
Picked up a Stock Club Race ESC. Will be using a 17.5 motor. Just wondering what FDR should I aim for. Wont be using it for racing. Just want to run around my nearby parking lots.
Since it doesn't appear anyone has answered your question directly, YES, your sensor board is missing one of the pickups. There should be three of them and you only have the two. This will probably freak our your ESC a bit and certainly won't allow you to achieve full power (the ESC likely has to revert to sensorless mode). Contact Speed Passion and have them send you a replacement. I was looking at my collection of sensor boards and see that the soldering jobs on them are all over the map as far as quality.
erm, NO - check to the left of the red circle, there you will see the 3rd hall sensor I believe.
I think where the red circle is placed, is the space for the temp sensor that SP chooses not to have the OEM fit. GM have in the past used this same sensor board, and on their earlier ones there was this space, the later ones had the sensor.
You are correct. I guess I shouldn't look at stuff like this so late at night.
Hi guys can you please tell me if this sounds off ,
It's the mmm 17.5r motor and I'm just not sure if this sounds right
Please have a look at the YouTube video I made
http://youtu.be/B-oS62JgMAM
Sounds fine to me.
Cheers mate
