The Speed Passion Thread
#6976
What settings are u guys using for sensorless motors on the ex gt2.0. These escs don't seem to like sensorless motors. But work Awsome with sensored motors. It cogs Down low with sensorless. Also had a problem with my lvp cutting in way to early. So just turned it off and all good now.
#6977
hi...need help..
soon I/we are going to have a race on carpet (10x25 m)
car : 416 WE
Tires : Foam, shore 37 F/R (controlled tires based on rules), i used 58 mm outer diameter
I'm using SP GT 2.1 Pro Stock with single Caps 25V 2700 in it. software #528 installed w/ SP V.3 11.5T ...and here are my sets :
1.1
2.2
3.5
4.7
5.4
6.4
7.1
8.2
9.6
10.2
11.-
12.9
13.5
14.4
15.4
problem is : using FDR 7.7 (105/28*2.055)...the looked so late to catch up the front car at straight lane on last practice.... but the speed at corners and sweeper looked good... motor runs after running 30 mins at 75 deg...any suggestion...please..? thanks..
car : 416 WE
1.1
2.2
3.5
4.7
5.4
6.4
7.1
8.2
9.6
10.2
11.-
12.9
13.5
14.4
15.4
#6978
DROP 13, 14, and 15, by two numbers
#6979
#6981
I just purchased a Cirtix Spec Stock ESC. I can't seem to get it to setup. I'm using a Helios X-10 and Ballistic Motor. I've tried an older Novak SS as well, but after the set-up process, the ESC still stays at neutral. I've tried reversing the throttle on the Rx, turning the epa from 150 to 100, but nothing seems to work. Can someone give me some idea what to do?
#6982
Sometimes the Citrix doesn't like Novak motors. Try another motor that is not Novak.
#6983
Try this:
Unplug the sensor harness, turn the ESC on, plug the harness back in.
#6987
Where do I find the software for my comp.to down load the new software for esc.a part # would be nice.
#6989
http://www.speedpassion.net/us/download.asp
Item that you will need is here..
http://www.speedpassion.net/us/produ...=SPLCD01&c=OPT
#6990
My son and I are jumpin' back in to the hobby after apx 4+ years away. I am impressed with the quality and usability of the SP products. I purchased a GT2.1Pro Stock for my TC6 and a 2.1EX for my 1/12th. Fantastic speed controls! With the help of Team Driver Billy Sydor, the steepness of the learning curve has truly been lessened. The new 1 cell motors are the icing on the cake!
Thanks to Bill for all his help,
--and--
Thanks to Speed Passion for making outstanding products!
--and--
