The Speed Passion Thread >
Like Tree57Likes
Old 05-16-2010, 05:53 PM
  #4321
I ran a reciever pack but when you turn on the reciever pack you still had to turn on the speed control. It would work without the reciever pack but the servo was way slow (of course).
Josh Cyrul is offline
Old 05-16-2010, 06:19 PM
  #4322
mr crum's Avatar
i run rec. pack and didnt have to turn on speedo and had normal speed on servo guess it depends on which rec. pack you run
mr crum is offline
Old 05-16-2010, 08:45 PM
  #4323
skypilot's Avatar
Trader Rating: 14 (100%+)
17.5 expert race results, another tq and win for sp, the only car with SP esc and motor, (so far )
http://fantasyworldracing.com/index....=111&Itemid=58
tried a couple different setting, actually lowering the throttle delay and rpm delay it went faster and ran cooler, still working on the magic gear ratio/esc setup. its only going to get better
skypilot is offline
Old 05-16-2010, 10:03 PM
  #4324
KWT-NITRO's Avatar
Originally Posted by KWT-NITRO
hey guys,
i just bought a speed passion emotion combo for my M18Pro, i have a small question about the neutral range?? what is it exactly and how does it change the car's performance when changing the neutral range??
cheers
Ali
anyone??
KWT-NITRO is offline
Old 05-16-2010, 10:15 PM
  #4325
Rdog's Avatar
Trader Rating: 83 (100%+)
Hey Richie can you pm me your setting and fdr? Thanks man
Rdog is offline
Old 05-16-2010, 11:01 PM
  #4326
razzor's Avatar
would suggest putting the esc on as it will have more power. I noticed that when the switch is off the led on the esc is not as bright as when its switched on. This to me says that the voltage is not what it should be.
razzor is offline
Old 05-17-2010, 03:21 AM
  #4327
mr crum's Avatar
well im just as fast as the cars with tekins without the switch on so i wont take the risk on burnin somethin up
mr crum is offline
Old 05-17-2010, 04:44 AM
  #4328
Trader Rating: 23 (100%+)
anyone??
Neutral range is the amount of "play" in the trigger. So the larger the number the more you have to pull the trigger to get the car to go forward or operate the brakes. It doesn't change the cars performance as much as the performance of your radio as a interface to the car. Check out the included picture for clarification.
-j
File Type: bmp
Anemic_SluG is offline
Old 05-17-2010, 11:44 AM
  #4329
syndr0me's Avatar
Trader Rating: 32 (100%+)
Are these available anywhere in the US?
http://www.speedpassion.net/en/productDetails.asp?p=103
syndr0me is offline
Old 05-17-2010, 12:51 PM
  #4330
gixer's Avatar
Quick question guys please.
What size are the connectors used on the SP V3 motors?
gixer is offline
Old 05-17-2010, 01:09 PM
  #4331
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
3 or 3.5mm i think
Marcos.J is offline
Old 05-17-2010, 01:10 PM
  #4332
MikeXray's Avatar
Trader Rating: 73 (100%+)
I am pretty sure it's 3.5mm, but I got a set from great planes and they do not fit snug like the ones that come with the motor, which would be an issue.
MikeXray is offline
Old 05-17-2010, 03:43 PM
  #4333
Hi guys, I'm set to try the 422 software down my club on Friday with v3 10.5
the track has a 20m straight and i was hoping someone has tried it with success..what are the main settings to play with? I don't want it too punchy on the infield but would like to rip down the short straight
cheers mark
mark williams is offline
Old 05-17-2010, 05:26 PM
  #4334
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Quick question ! Just picked up a GT 2.0 Is it possible to use the Hobbywing program LCD Box dont see why not but want to be 100% before i spend the $$$ Cant seem to find the SP ones anywhere and the HW is $22 shipped
TIA
IL_AudiRacer is offline
Old 05-17-2010, 05:29 PM
  #4335
mr crum's Avatar
3.5mm
mr crum is offline
