"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
#181
Hello Jilles,
I still use the original 416 two piece upper deck and the old bottom deck with the battery pushed to the rear. Is your basic rubber set up meant for the WE?
Thank you,
Ken
Thank you,
Ken
#183
Hello Jilles,
I replaced TRF 416 Shock O-ring to Tamiya Competition O-ring(BLUE)
Because TRF 416 Normal O-ring was too thick.
But I found that Shock oil Leak Problem when i used Competition O-ring.
and i experienced same problem when i user much-more perfect silicone 40 O-ring.
1. What kind of Shock O-ring you use?
2. Do you use Shock Clearance shim to avoid oil leak?
or Do you Always Check Shock Leak per Every race and refill shock or rebuild shock?
Thanks,
Bander.
Thanks,
Bander.
#184
Trader Rating: 23 (96%+)
hi jilles,,
i got my friend asking me, what are the major different between 416 and 416WE??
a few major point will do...thanks
#185
- Battery slots moved forward
- Short reversible suspension arms
- HL Damper cylinders
- Teflon sealed bearings
- 1 piece upper deck
- Revised motor mount & brace
- Larger front bumper
- No air scoop
- Different suspension blocks (for short arms)
- Different length drive shafts (for short arms)
- Low profile serrated wheel nuts
#186
Well, just got back from racing and the lighter shock oil was definately better. I went too far at first (from 450 to 300!) but then went back to 400 and just this small change made a difference to the chicane transition. Wanted to try a set of milk blue white and blue springs as I believe they are slightly harder than the standard white and blues??? but didn't get chance.
It was very warm this evening and lap times had dropped for most people from last week.
What sorts of changes do you make when going from cold to hot conditions? Just tyres?
Will hopefully get some more practice in this weekend to try the springs out.
Thanks for all your help so far,
Paul
#187
Hi Jilles
Paul
Paul
Only the white is harder on the milky blue / white set, as it has less coils. Rating (measured by Ling Tong aka 'linger') is 15.27lb for the original white, and 17.05 for the milky/white white.
The blues are still the same though.
HiH
Ed
#188
Another day in the office
Hi Jil,
just a reminder of a testing session with 6 TRF guys at one table.......
btw, however it seams nice to drive with Jilles, it's NOT! we are driving LiPo's and he was whooping our a** with 5 cell.
And now on the topic, I have a question.....every now and then I have this burning sensation between my toes, how do I fix that....hahahahahahaha
See you soon.
Z
See you soon.
Z
#189
Jilles,
For races with controlled tires, what do you change from morning heats, to the high noon and evening. e.g. at TITC and the worlds?
Thanks!
#190
Hi Jil,
See you soon.
Z
See you soon.
Z
or just so everyone happenes to be standing up? Happens to me when I get excited or in a hurry.
#191
Cheers Ed. Any suggestions if I wanted to go slightly harder all round then?
#194
Chris,
The diff pulli is on both side the same. The ceramic diff balls where from HPI, I got them when we were testing in Thailand for the worlds.
I make the shocks always with one o-ring and with the plastic shim, don't use any other grease. I just rebuild the shocks ones in a while.
Fastforward,
I always run the camber link pretty much level, this keeps the rear more stable entry and exit the corner. Should work the same on the TA-05.
Ken,
One or two piece topdeck is very similair. Sometimes I use the two piece topdeck to make the car more stiff, for more rotation in the corner.
Bander,
As I explain to Chris, I use Much More blue o-ring with the standard TRF shock shim. I rebuild the shock ones every race or practise because a shock always have some leak.
Edwintklee,
The biggest difference from the 416 and the 416WE is the chassis, and the WE version comes standard with short arm and spool which is 99% used.
Paul,
Nice to hear you improve the car.
From cold to warm weather the only thing I normally change is shock oil. The warmer it gets the harder shock oil I use. Most races are control tyres anyway but if you have the choice of tyres always go as hard as possible when it gets more hot.
Z,
Nice picture! It was great fun racing with you guys and trying to keep up with the Lipo speeds! Man, those cars are so fast on the straight!
See you soon!
Jilles
Fastforward,
Ken,
Bander,
Edwintklee,
Paul,
Z,
See you soon!
Jilles
#195
Rear camber link
My question on the 4mm and 3mm shims on the rear camber link. In your post above you say you like to keep the rear camber link level which I understand. Can the same thing be accomplished with 1mm and 0mm shims on the rear camber link?
My concern with a lot of shim is durability.
Ed, you might want to "chime in" on this one.
