T.O.P. Racing "Photon" 1/10 EP Touring Car
#4576
#4579
I would suggest trying my setup I posted back in mid march. The higher you go on the roll center and the stiffer you make the back(Standing the rear shock up) the more your car is going to wanna flip.
Maybe shorten the links to middle hole if you arent already and go lower in the rear roll center to med low if you dont wanna lower your front RS.
That makes sense, will go with the lower roll centres / shorter links.
Alan
#4580
Hey guys
So i went the a state title event here in oz last weekend with the photon in rubber 17.5. i was amazed at how many of these cars have popped up since november last year when i travelled to the sasme track. last year i was the only one to run one, this year i counted six at least.
car was dialed, i managed to come 15th out of 33 drivers which in a field of the quality it was i was really happy with. First qualifier i broke my first outdrive hex in the spool. many of you have done this however when i built the kit initially 12 months ago i used the v.1 spool. even though the updated one was in my kit. that means it lasted 12 months of pretty solid racing. i gather the v.2 spool was made a bit stronger in which case it should last me years.
so i thought i would drop a line on here to say awesome car top. built well, strong and a really easy car to drive. pity i couldn't put it in the a's but that is all driver not car.
won't be straying from this car for quite some time i wouldn't think.
#4583
PO-SDT008 is steel !
#4585
they wil leak without them
#4586
steering chatter
Hi,
Been reading thru the thread, and it seems that not many of you are experiencing steering chatter.
well... i have steering chatter that is quite bad on my photon. I am using the steel bones with the roche solid axle.
i understand that chatter is a characteristic of running solid axles in the front... but can anyone tell me how to (if possible) reduce the chatter?
thanks in advance
sam
thanks in advance
sam
#4588
#4590
Hi,
thanks in advance
sam
thanks in advance
sam
