HPI Cup Racer 1M
#2386
How about if the bottom happens to hit the ground, does it wreck the whole car, or just leave a mark, and the car keeps on going?
I was thinking of rally, since I'm not sure whether am I going to like touring, since there are not so many places to drive.
#2389
To Raman
How did the Alpine do back in the old days? Was it a competitor for Alfa & BMW?
#2390
For the motor I was thinking Ez-run 4000kv, on 2s or 3s.
I wouldn't want to make it a missile on the first runs, i can upgrade if the ~20-30mph isn't enough
How about the weak links, not so plastic axle cups are a must? anything else?
#2391
The rivalry back then (ETCC) was mainly Alfa, BMW, and Ford (capri i think) in division 2. The 911T (4 cyl) may have been in there as well.
#2392
The center front plastic drive cup is a weak link. I would replace it with an Exotek alloy one. The orange front lower inner pin holder can bend if the front tires/suspension get hit. I would double it up.
#2394
im borrowing a 510 cup racer from a friend and now i want one lol
#2395
If you have the nut that's on the bottom set flush to the end of the screw you should not have problems with limited suspension travel though it does look like there's very little freedom of movement. This rod is acts as a steering knuckle stopper only. You can use a shorter threaded screw and nut so it doesn't pass through both upper and lower arms. There's a couple of pics on this thread. Look for MikeR's posts.
Yes, on my CR the Z661 nut is flush with the Z419 screw. Suspension arm travel is very stiff and less than 5mm. I couldn't find MikeR's posts ?
ps here's a pic taken in the ACT back in the 70's...it's for Alfa Milano fans...the car is my fathers and is a 58 build 4 with 5 speed, twin cam, twin Solex double barrel 48mm carbs...paint is white with red interior...instrument cluster has a ton of elegantly placed gauges and switches...from memory olio temp and pressure, batt volt, benzene, aqua temp, tach and the mandatory speedo...drum brakes as disc came out in 59...very few were made...something like less than 2000...body was designed by the late Pininfarina...oh yeah...nearly forgot to tell it's a removable hardtop as well.
#2396
Thks for the reply Sydewynder,
#2399
