Tamiya TRF415
Anybody know the part number for those little hollow aluminum doodads that go on the end of the hinge pins and into the support block? I'd like to have a couple spares in case I drop one in the parking lot...
P/N 50994 for regular
P/N 53709 for flourine coated version.
Originally Posted by veecee
#3454351
anyone knopw how much it costs to get the yokomo front diff for the 415?
Ok here is another question, what is the effect of changing from 4*castor to a 2*castor
Thanks, Charles
Thanks, Charles
Thanks, Charles
Thanks, Charles
Thanks, Kevin!
Im going to use a stock motor on my 415. What size pinion should I use? I have the 102T spur
What motor? (ROAR, Quad mag, Monster, p2k2 etc)
What size is the track? (mainly straight length)
Rule of thumb is you want the motor topping out roughly 2/3rds to 3/4rs down the length of the longest straight.
Best advice is go to a local track, and ask people there what they run.
Personally I always err a little on the cautious side to begin with, so if some suggests (for example) and FDR of 7.5, i'll go around 7.8 to start, then work my way up. (remember, the lower the FDR, the higher the top speed/lower the acceleration)
HiH
Ed
Thanks bender
Charles
Charles
If its a stocker you can try maybe 37-40 range of pinons...
set up
Hello tryhard, is it possible to you to ask at David Spachett his set up for the GP world cup at CRF in swiss, cause i will go here soon, many thanks to do it if it is possible, best regards Ed...
Does the 415MSX2 come with a center locked pulley or with a center oneway?
The MSX comes with a center oneway!
