Tamiya TRF415
Location: SOCAL the fastest mini cooper guys in the nation
Thanks Max and I will let Mickey know I don't know his current setup but I am forwarding any info to him and appreciate the help
Does anyone know what kind of lipo clearance I can get from using a trf415msxx stick pack conversion? I tried using the search but it didn't yield any results. Thanks.
This question is for a friend of mine:
Can anyone help with some feedback on what to do when my 415 msxx has no rear traction on exit of the corner and no nothing is bent. He has also tried several spring and droop settings I mean a whole crap load of different variations. Please help we call his car a "The TT01 delux drift edition" We must help this man before he blows up his car with a grenade and could potentially hurt himself in the act. So if you have any feedback on rear traction issues, problems, remedys, and or suggestions please let her rip.
P.S. He has about 40 sets of tires by 5 different manufactures so its not the tires
Use wider tire or lighten up the rear end of the car. Or maybe try it the vise versa. I am pretty sure it's the weight distrbution problem. try a different aero body too, it effect the weight distro at high speed. I heard a lot of trf416 guys have the same problem because the motor moved more rearward. good luck.
The stock form can still fit a 18mm height airplane lipo perfectly, that's for sure.
Ok, I found running more droop at the rear good for killing understeer on my 415. Interesting.
Also with the ball diffs, use Yokomo plates, carbon nitrate balls and use diff covers on them (I forget who make them again) and usually for 540 Pro or Stock you don't need to touch the diff again for ages. Mod is a different matter entirely.
Oh yeah, when was the last time he rebuilt his diff.... that has a huge impact on performance. Also make sure it's set correctly, tight enough to be locked, but not binding. Thankfully the alloy tamiya diffs are a breeze to get feeling nice, whilst still tight. Have a look at this document... it's for the 416, but still applies to the 415.
http://www.thard.co.uk/TRF416-Things2know.doc
Oh, and check the droop, should be running 5/4 f/r outdoors (set on a gauge off the chassis bottom, measured off underneath the outer hinge pins).
HiH
Ed
HiH
Ed
hey guys I'm the fence here. I trying to decide if I should go Lipo or not.
I run a Msx MRE. Front spool and in stock racing (27turn)
what I really want to know what the preference for you guy's. I know if I go lipo I will have to figure out how to rebalance the car again.
The real question Which is faster, more punch. I know the long term lipo. but I'm so undecided right now. I have to either NiHm or Lipo in the next week or so.
also Which Lipo hard pack actully fit the Msx Mre.
thanks in advance
thanks in advance
go rebalance your car its worth it. Lipo has more punch and lipo will last longer compared to a 6cell nimh pack.
Speaking of lipos, does anyone know where I can find painfully cheap 4000mah-ish 15c 7.4v lipos that would fit in a trf415msxx (H:18mm L:135?)?
I would use a hard cased lipo. the balance would be a little problem if you put it further out from the center, it may not be legal for some club race though. but your car can run 100g less without using the balance weight. give you the edge.
for the legal race, I would still use nimh because the weight is more concentrated. while everyone else have to fit into the minimal weight, it is where you place those weight which makes important to the car's handling.
All of our club race, is required to make the 1525 gram weight minimum, yes that for all club race's we do.
So should I go Lipo or Stay with cells and go for the 4600 since their supposed to be much more robust and way more stable then the 42's .
I'm on the fence as we speak and really need to make a sound decision on which path I should venture down.
Cheers
Cheers
put the balancing weight on the inner side of the lipo
Super Moderator
Cheers
Cheers
folks, whats the difference between the 415msx and the msxx?
