Tamiya TRF415
RW spurs and pinions for me... expensive, but the the best I've used
Originally Posted by Eirik
I know Marc uses Xenon 64dp gears
Tech Legend
Trader Rating: 51 (100%+)
kewdawg you got a 415!!!!!!!!!!!!! Is it purple.
Originally Posted by Charles Godwin
Who does xenon in the uk?
I know of only one place to get Xenon in the UK and that is through Smart Racing, but when ever i place a order with rcchamp i'll usually order something by Xenon.
Charles
Charles
Originally Posted by CRiXman
Hi,
A lot of questions regarding front1 way diffs for the MRE. Apparently there will be one coming shortly.. How shortly?? I dunno.
For the time being, (and since I am very impatient) I bought the front oneway system for the TRF 415. I fitted it on and it fits fine. Tonight I will give it a spin and tell you all how it worked and wheter it was worth it..
Here are the part numbers for the conversion:
- Tamiya TRF415 Front One-way Housing: TAM51059
- Tamiya TRF415 Light Weight One-Way Drive Cup: TAM53704
the other parts were all from the orignal MRE package..
However I do recommend the following, if you don't want to undo/dammage the solid axle:
- Get a new MRE Front Pulley and
- bearings that hold the front Diff.
Hope this helps some..
How many Km/hour Marc Rheinard's Car can go?
IT WORKS BEAUTIFULLY!!!!!!!!!!!!!!!! That's all I have to say...
Charles
Charles
Harsh, check PM!
vic
vic
What are the differences between
an A block
and say a :
XA block
there's soo many blocks is's kinda confusing. I know the standard single letter blocks determine toe and such. But what's this whole " X " block thing about ?
thanx in advance
an A block
and say a :
XA block
thanx in advance
X is like a - on a number. Or 0 by it's self. All of the X blocks are shorter than an A block and get shorter the farther down the alphabet you go.
from longest to shortest:
E
A
X
XA
XD
E
A
X
XA
XD
Originally Posted by buboy28
thanks for the update will also try what you've done with my MRE
but I definately needed it ASAP
