Like Tree25Likes
Old 09-11-2017, 07:20 AM   #9541
Trader Rating: 24 (100%+)
thefnshow is offline   Reply With Quote
Old 09-11-2017, 09:19 PM   #9542
ImacFanatic's Avatar
Originally Posted by Oleg Babich View Post
Any brand 6x3mm round shims of the desirable thickness.
Awesomatix offers 0,5mm, 1mm, 1,75mm thickness shims.
SH0.5 - 6x3x0.5mm Spacer (Silver) x 10 ? AWESOMATIX
SH1.0 - 6x3x1.0mm Spacer (Gray) x 10 ? AWESOMATIX
thank you, considering making a CF shim in 2mm , but ill get those in the mean time.
ImacFanatic is offline   Reply With Quote
Old 09-12-2017, 03:16 PM   #9543
Trader Rating: 17 (100%+)
I just listed a front diff and front spool and upper deck evo parts
Rcforlife13 is offline   Reply With Quote
Old 09-23-2017, 03:04 PM   #9544
does anybody know where i can get part am38 ? not listed on their site
Old 09-24-2017, 05:13 AM   #9545
Only few pieces of AM38 were produced for tests.
Oleg Babich is offline   Reply With Quote
Old 09-30-2017, 09:42 AM   #9546
I'm looking for another nice condition A700. I'd prefer an aluminum chassis Evo but open to anything.
Please PM me if you are interested in selling one.
RollingChicane2 is offline   Reply With Quote
Old 10-07-2017, 07:33 AM   #9547
G-rem's Avatar
Hi there,
question about rear bump steer: is there any influence by having the rear toe-in turnbuckle angled forward at bulkhead side (and so rearward at hub side)?
That's pretty tricky to explain; I mean: if I put shims @ bulkhead side where the rear toe-in turnbuckle is attached (see step 18 in the A700 Evo II manual); this will induce a forward angle of the turnbuckle; what will be the potential effect?
Thanks in advance for helping me!
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 10-08-2017, 03:36 PM   #9548
I have a front one way for the A700. I will not run it. If anyone is interested in it, shoot me a PM.
Old 10-09-2017, 02:06 PM   #9549
G-rem's Avatar
Originally Posted by G-rem View Post
Hi there,
Regards,
G-rem
Anyone?
Old 10-11-2017, 08:03 PM   #9550
Anyone?
I shimmed mine out to eliminate interference and there are no negative side effects.
Technically it would change the effective overall length of the turnbuckle ever so slightly but you can easily adjust for that in the shims you place on the outboard side.
G-rem likes this.
Old 10-23-2017, 05:15 PM   #9551
daktulos's Avatar
Hi there,
Regards,
G-rem
2 weeks late
I am in the middle of some testing and have the car almost disassembled when waiting for parts so I take the opportunity to make some checkup. I was also curious why John Doukakis on his blog have a picture of his 800 with AM14LS arms at the rear...
With the car on a setup station without shocks attached I played between the car at full compression and at 5mm height. Chassis always parallel from the working table. I didn't play with induced rake and roll because it was too difficult to replicate...
I was assuming the less forward/backward angle the turnbuckle and longer the arms the more progressive the action.
I was wrong or I was not able mesure it correctly lol
What I found is that the action is comparable on both side one with a AM23-1 and the other with a AM14-1. I was able to shim the ball studs to have the same toe at full compression and at 5mm. The test was done on a car with RFG that give a big amount of rearward angle when using AM23-1.
But...I may have a clue...the only thing that may have a "mesurable" effect on the bench and at the track is the rigidity of the assembly when the links are straight. Probably in the same order of subtil effect that can give AM19-4 at the back.
Enough bench racing I will try on the track in a week or two to see if I feel a difference and will report back.
See you!
Alexandre
G-rem likes this.
daktulos is offline   Reply With Quote
Old 10-24-2017, 12:28 AM   #9552
G-rem's Avatar
Thanks a lot for a such detailed iteration! Can't wait to hear from your track test
Old 10-27-2017, 09:16 AM   #9553
howardcano's Avatar
Trader Rating: 35 (100%+)
I have always run the front steering arms on the rear of my A700 cars, for extra strength and less slop (a given amount of play in the ball cup translates to less toe change with the longer arm). Bump steer is easily set to zero (or whatever you might desire) with shims to change the angle of the arm.
I initially got some strange looks from other Awesomatix drivers, but over the years I's also heard of others doing the same.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-29-2017, 08:00 AM   #9554
TENCHO's Avatar
anyone have a good rear diff for sale? i can't get mine to stop slipping. the gears don't mesh right
Jesus Sierra-
Stock Touring 17.5-TamiyaTRF416/Exotek/SpecR mix
VTA-SpecR R1/Novak Ballistic 25.5
F1-VBC LightningF
TENCHO is offline   Reply With Quote
Old 10-29-2017, 02:04 PM   #9555
Default Setup
Hey people,
Does anyone have a favourite set up they could recommend me?
The track I'm racing at for the next little while is a 36'x100', sweeper onto the straight and a sweeper off the straight, technical in the infield. Its on Crc Black Carpet
One10 Raceway, it pops up on google, if anyone would like to see the exact layout.
ColinH is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
