Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 04-30-2012, 04:40 PM
  #2086
Trader Rating: 27 (100%+)
Originally Posted by hanulec
That is a nice fan...
Yes, it is similar to the fan you can buy from http://www.sidepieceracing.com/ .
MDawson is offline
Old 05-01-2012, 03:58 AM
  #2087
hana166's Avatar
Originally Posted by MDawson
This is a good question for Oleg.
I rarely ran straight pins on the Tamiya, TOP and Xray cars with a spool. Always felt like the car initiated better with some arm sweep in the car. I am trying to visualize the difference between the pivot vs. hinge pin caster blocks and can't rationalize what the difference would be.
Something to also consider is that Xray made really good use of arm sweep in the FK series of their cars. There was a totally different feel you could get out of a car with outboard rear toe vs inboard rear toe. Their cars always cornered well under power with the outboard toe.
I don't have the car in front of me but I would think we have straight pins and are effectively dialing in outboard toe.
Lets hear what the experts say...
Well I'm no expert but it was the first thing I asked Oleg when I got the car, there is no sweep, and probably quite tricky to incorporate into the current design.
Agree with you Mark about rear toe, I think outboard is one of the main reasons for the A700's handling characteristics.
hana166 is offline
Old 05-01-2012, 04:47 AM
  #2088
I looked at the chassis last night - there are inner & outer holes on the chassis for the arm pivot mounts. I haven't tried it but you seemingly can run front/front on the outer holes and front/rear on the inner holes to create arm sweep. But again, not sure of the total effect due to the way the hubs are mounted.
MDawson is offline
Old 05-01-2012, 06:45 AM
  #2089
hana166's Avatar
I thought those holes were a legacy from a previous prototype with shorter wishbones, surely the distance between those holes would create too big an angle of arm sweep?
hana166 is offline
Old 05-01-2012, 07:11 AM
  #2090
erchn's Avatar
Agreed, based on my calculations, the distance is quite a bit too far. I was never very good at trig, but the Interwebs have told me it should be around 3/4mm for 1 degree of sweep and 1.5mm for 2 degrees. Here's how I calculated it:
Code:
r = 44mm (distance between arm mount locations)
length of circular arc = degrees * (PI/180) * r
1 degree
1 * (3.141/180) * 44 = .7679mm
2 degrees
2 * (3.141/180) * 44 = 1.535mm
Of course, these could be totally wrong, so maybe someone with more skills can double check. ;-)
erchn is offline
Old 05-01-2012, 08:35 AM
  #2091
Originally Posted by erchn
Hi all,
I've been wondering whether arm sweep would be beneficial on the A700. I haven't measured whether the A700 has arm sweep built into the chassis for the front arm mounts, BTW. I'm also wondering whether it's even appropriate given the swivel nature of the way uprights mount to the arm.
Does anyone have thoughts on that subject in respect to the A700, description?
Thanks,
Ethan
We'll check the effect of the inner sweep of the lower arm, though, I believe it will be much less noticeable than for conventional suspension due to lack of outer hinge pins in our suspension.
You have very easy possibility to check the influence of the upper arms sweep on A700. It does not require any additional parts and part's reworking.
Oleg Babich is offline
Old 05-01-2012, 08:45 AM
  #2092
erchn's Avatar
Thanks Oleg. I'm certainly interested in the results.
erchn is offline
Old 05-01-2012, 09:48 AM
  #2093
TryHard's Avatar
I think I checked this before, but the lower arm interfers with the damper if you try to run sweep, and you basically can't get the arm into the mounting hole... It'd be a lot of sweep too!!
Now upper arm sweep sounds like something interesting to try *adds to test list*
Regards
Ed
TryHard is offline
Old 05-01-2012, 05:26 PM
  #2094
JayBee's Avatar
Trader Rating: 31 (100%+)
A little late but all done. A little sloppy with the electronics install; kind of just wanted to get it finished
I had to bring back the Ol Skool Parma Mohawk...I wanna try it next carpet season.
Attached Thumbnails Awesomatix EP Touring Car (A700 Shaft Drive)-2012-04-27_20-21-02_348.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-2012-04-28_20-01-05_457.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-2012-04-28_20-04-34_779.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-2012-04-29_20-12-09_827.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-2012-04-29_20-14-09_904.jpg
JayBee is offline
Old 05-01-2012, 05:31 PM
  #2095
Now break the champagne bottle over its hood! j/k
Were you going to cut the deck?
MDawson is offline
Old 05-01-2012, 05:41 PM
  #2096
JayBee's Avatar
If you're meaning the top deck.....not sure
JayBee is offline
Old 05-02-2012, 10:26 AM
  #2097
Congratulations to Hugo Ragaut with 2nd place at 2nd round of French Championship 2012 ( open modified)!
Setup of Hugo's A700 car is on our website now:
http://awesomatix.com/download/
Old 05-02-2012, 11:33 AM
  #2098
And the car kit, may be back in stock one day?
february is offline
Old 05-02-2012, 12:16 PM
  #2099
According to Oleg: end of may.
Hugo is offline
Old 05-03-2012, 12:53 PM
  #2100
theatriks's Avatar
Is the long upper arm set just AT-25 x 8 plus 2 x AM-18
theatriks is offline
