XRAY T2’009
Old 09-25-2009, 10:41 AM
  #1831
Johnny Wishbone's Avatar
Originally Posted by chensleyrc1
Sorry, all I did was answer the mans question, he asked if the parts would work, and the answer was yes. But thanks for the details, I'm sure he appreciates it.
And FK, it's not your time or money to waste.
I actually had to look that acronym up.
But yes I do know some racers use the 008/009 arms on the 007 to achieve the middle shock mount location on the arm also. Just one more tuning option alot of racers don't think about.
I only mentioned it as one of our guys changed just one of the arms and ended up with a split set and couldn't figure out why his car acted strange in the corners. Sorry if I insulted anyone.
Johnny Wishbone is offline
Old 09-25-2009, 11:39 AM
  #1832
Trader Rating: 38 (100%+)
Originally Posted by dodgeguy
Chris you are such an @ss! You are always stirring something up.
We will see who's laughing when I finish a half lap in front of you next time we race!!J/K
chensleyrc1 is offline
Old 09-25-2009, 02:39 PM
  #1833
yokemad's Avatar
hi guys
my car has good balanced r-l but I've check the weight it's 1550gm where min allowed 1450gm so it's 100gm over weight ...
I don't use any tray and packs sits perfectly to the battery holes...
should I hang out the battery to remove those weight leads and balance the car? Which I know is not the ideal way to balance the car...
all added weight leads on battery side...
any advice welcome
thanx in advance
yokemad is offline
Old 09-25-2009, 02:46 PM
  #1834
body with heavy paint can add a ton of weight.
i don't really hang my batteries off the side, but i do use a ppd plate with smc 5200 40c with 28g of weight on the side of the battery and i come in weight at about 1460 or so.
Dondor is offline
Old 09-25-2009, 03:02 PM
  #1835
Originally Posted by yokemad
hi guys
any advice welcome
thanx in advance
Balance is very important, but how to get it can be hard to do. Obviously dumping 100gms should be done for sure. Probably a pic of your setup or a discription of what rxr, sc, servo and motor would help in figuring out what to do, also if your running extra fans or heat sinks on the motor or sc too. Are you using the balance buttons to check your car or scaling it? to know that your balance is good right now. The xray setup with the "L" brackets and the brass weights for the middle of the car work well, but then you have your pack hanging out there, which sort of defeats the whole idea of the lipo pads on the car. Need a little more info about your rig.
Old 09-25-2009, 03:45 PM
  #1836
yokemad's Avatar
ok
Lrp cooler
Hacker-Orion motors,RS pro esc,Spectrum pro normal receiver,KO 2413 ICS servo,amb transponder...
on the other side IP5000 and IP3800 lipos with added weight leads both 234 grams and 30+30 grams of weight on chassis in front and rear of the lipo nothing else
That huge motor cooler makes the car harder to balance,It's own weight and extra weight on the lipo side to balance...
I think That's the trouble but I don't want to remove it to be honest...
Also Bodyshell another 100grams
Thanx for all helpfull posts
yokemad is offline
Old 09-25-2009, 03:52 PM
  #1837
RLMW VQ's Avatar
light weight bodys are around 60 or so grams that would help you and yess loose the motor cooler if you can.
RLMW VQ is offline
Old 09-25-2009, 04:05 PM
  #1838
The cooler will present a problem. From what I saw most guys are dumping the coolers and making fan holders out of lexan, just enough to blow air over the motor and not worry about pulling heat from the motor with the heat sink. The spectrum normal rxr is another item that if possible go to one of the smaller ones. Like you said, you now thats the biggest part of the balance problem right there (cooler) I'm sure you have heard all the other stuff about smaller this and that, and thats great if its in the budget, but if not you have to work with what you have and, again, the cooler is a biggy, I fought with the exact same issue till I talked to Drew Ellis and he showed me his fan holder, bare minimum, but it keeps the air moving over the motor which seems to help more than the heat sink. I'd start with that.
Old 09-25-2009, 04:51 PM
  #1839
yokemad's Avatar
Yup
That cooler must be min 50 grams and another 50 added the other side of the car to balance comes to 100 grams which is My target to cut out
I shoud find out some pictures of that Lexan Fan holder stuff
Thanx guys
yokemad is offline
Old 09-25-2009, 05:06 PM
  #1840
Default Xray lipo chassis balance weights #309860
Hi,
Any body knows which online rc shops sells the #309860 weights?
Have tried to order thru my local hobby shop but was told even xray do not have the stock?
Please advice..
Thks!
Ben
benokw is offline
Old 09-25-2009, 05:20 PM
  #1841
P2
P2's Avatar
Trader Rating: 15 (100%+)
Default Fan
Yup
Thanx guys
Or you can do what I did and just Shoegoo it behind the motor....works great
P2 is offline
Old 09-25-2009, 05:31 PM
  #1842
Regional Moderator
CarbonJoe's Avatar
Originally Posted by benokw
Hi,
Please advice..
Thks!
Ben
Amain has them in stock
http://www.amainhobbies.com/advanced...09860&x=7&y=14
CarbonJoe is offline
Old 09-25-2009, 05:46 PM
  #1843
gonzo416's Avatar
Trader Rating: 39 (98%+)
Can anyone with a perfectly balanced car with very low but legal weight post pics please?
gonzo416 is offline
Old 09-25-2009, 05:47 PM
  #1844
gonzo416's Avatar
front to back and left to right.
gonzo416 is offline
Old 09-25-2009, 05:51 PM
  #1845
I got a almost brand new 009 for sale. PM me if interested.
billythekid is offline
