Tamiya TB-02
#691
Originally posted by izzyracer
The orginal TB02 Ball diffs feel inconsistent when rotated freely. It's smooth but gets tight then loose when rotated slowly. have you guys experience this situation ...
I think the molding of the diff plastic (tight-loose-tight-loose) flexes the screw and fatigued it.
All my EvoIIIs & TA04S use the same screw and none have broken it ever, so why TB02 if not for that??
#693
After winning the Laurel gt3 class with my tao3r I've finally gotten my long awaited tbo2 so I could retire my old ride. I'm not sure though. It will probably be a while before I build it but I have to say the only beef I have with it is the limited gearing motor mount. Wyd you were very impressive in the gt2 class. I am assuming you used 48 pitch gears? Can this car be competitive in all gt classes using only 64 pitch gearing?
#694
NCC, you really can't use 64 or 48 pitch gears in the TB. You have to mickey-Mouse with the motor spacing to try to get a mesh figured out, plus getting a spur that small is a royal pain in the butt. It's funny you don't like the fixed gearing, isn't that what the 03 had?
#695
Tech Legend
Trader Rating: 51 (100%+)
The car was on rails and was very easy to drive. Had a great day at the TCS.
The gearing on the 03 is actually better as you can use the metric 64 spur and then gearing is very open. I have the Tamiya pinions 20 to 29 and then I used the normal 64 pitch gears (non metric) to get anything I needed above that with no problems and no additional noise in the gearing. I think the 03 is better for gearing than my TB-02 but I don't have as many suspension options on the 03 as far as shock towers and a arms so that hurts me more than the limited gearing on the TB-02.
#696
Can't you guys just take a dremel to the holes and make it an adjustable mount?
#698
Tech Legend
Originally posted by Hebiki
that would be deemed illegal. these cars are being used for TCS.
#700
Originally posted by wyd
It would be illegal but then you still have no way to to adjust the motor as you would still have to dremel out the back of the chassis and that would also be illegal. To bad they didn't make it with an adjustable motor mount, carbon fiber tub chassis with low sides ( kinda like the 04) because then the car would be even better than it already is.
#701
is there any available steel outdrive and diff gears for the TB02? I'm plan to use a TB02 for offroad rally, the course includes jumps designed for Trucks and buggies.
#702
Thanks for the response. I run 64 pitch on my o3 and I can get any gearing I want for all three classes by only changing the pinions.
Wyd I agree with you that tuning options out weighs gearing only options. I'm anxiously awaiting the graphite tub.
#704
Would you guys get upset if I ran my TB-02 at the TCS nats?
