Old 06-27-2005, 01:19 PM   #3151
Csaari77's Avatar
Trader Rating: 34 (100%+)
What is the internal transmission ratio. I haven't found it yet, and I need to get a gearing chart around for the car.
Also, does anyone know how to gear a tamiya dyna-run motor? I think it's a 13T, but I'm not really sure.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 06-27-2005, 03:51 PM   #3152
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i think its 2.135, if i remember right...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-27-2005, 09:24 PM   #3153
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
mistake ...
FlyinGT is offline   Reply With Quote
Old 06-27-2005, 09:24 PM   #3154
FlyinGT's Avatar
2.133
Old 07-11-2005, 07:05 AM   #3155
I have a trf414m2 and I am looking for chassis for it who can help me
ptjonesus is offline   Reply With Quote
Old 07-11-2005, 11:38 AM   #3156
Send a message via AIM to odawg315
are you looking to buy a chasis?
odawg315 is offline   Reply With Quote
Old 07-11-2005, 02:28 PM   #3157
yes I am
Old 07-12-2005, 03:18 AM   #3158
Do you have one for sell the chassis are getting hard to find
Old 10-05-2005, 10:21 PM   #3159
GReddy's Avatar
Send a message via AIM to GReddy
is it true that a 414 can only fit up to 3000 packs?
GReddy is offline   Reply With Quote
Old 10-05-2005, 10:49 PM   #3160
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
I currently use GP 3300s on my 414M w/ no problems.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 10-21-2005, 02:04 PM   #3161
I put TRF 414M WCR on sale forum, have a look (pics included!).
trf_skyline is offline   Reply With Quote
Old 11-03-2005, 05:27 AM   #3162
Default Spool & EVO3 suspension blocks
Hi, I'll be trying out an old 414WC shortly. I've got two questions though..
1) Will the 415 spool fit?
2) Which EVO3 suspension blocks are suitable? There seem to be 4 different widths available..
pUs2 is offline   Reply With Quote
Old 11-03-2005, 06:22 AM   #3163
TRF415boy's Avatar
there is no spool available for that car and the one from the TRF415 will not fit.
The toe blocks are all suitable, it all depends on the setup you want to use.
A corresponds to what's used all around aopart from the block that is completely at the back of the car. There, A will give 0deg inboard toe (the car has 2deg outboard toe), B will give 0.5deg, C 1deg, D 1.5deg. We usually used the max amount of toe on that car.
TRF415boy is offline   Reply With Quote
Old 11-03-2005, 09:49 AM   #3164
You can build a spool for the 4X4 series using the the gear diff from the TA04 and getting the locking axle option from the Pajero kit. It is a brass spline that fits over both outdrives and locks the axle. You void the internal gears form the gear diff and maily just use the housing. I do not have the pt numbers for what to order though sorry.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 11-05-2005, 07:05 AM   #3165
JRRobiso's Avatar
Post TA-05 Tamiya Spool retro fit for TRF414M
Would the TA-05 Tamiya spool fit the TRF414M? The reason I asked, it still run my 414M kit for club racing & I like the way the spool handles on my TRF415. No after market RC company made one when the 414M was in it's prime years ago. I tried installing the Tamiya spool for the TB EVO4 & it was a direct fit between the bulkheads but the center hole of the diff pulley was too small to fit over the diff housing (the hole on the diff gear for the EVO4 is bigger in diameter). Any replies would be appreciated. Thanks in advance.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
