Tekin RS ESC sensored
#3886
the problem of this popup appears only on 3.25 and not any previous version. If the reasoning behind this is that it's impossible to get it to work in 100% of the configuration than I agree... It should work in 99.x% not the other way around.
#3887
sorry, i should have been clearer. We both had a GM 10.5t pro. His motor didn't scream on the strait and mine did (must be the timing thing). More testing to do. I do think that this esc rocks on small tracks. I only need to figure out the settings on the longer staits. Even though i got that weird message it seems that the esc is doing fine.
I drive with a pro10 (235mm) car.
#3888
On my club the Tekin is equal to the SPX.
On the longer tracks the SPX and the GM are faster.
Just wait. The turbo is coming and than it rocks also on the long tracks.
The GM motor is not a RPM motor.
#3889
yeah the gm is less rpm but i get the feeling it stays a little cooler then a lrp 10.5t. The guys with a lrp really got hot motors.
The fact is that we both had the same motors but he had a lower rollout then mine and top speed was roughly the same at the end. Maybe when i put one less tooth pinion in, 20 instead of 21, with higher boost 25 instead of 22,that the extra speed i noticed at the end will come a little earlier on the strait.
Indeed lets wait for the new version! ( in the meantime i will keep on testing
#3891
anyone got a good setup for brushed stock on a medium sized track? RS pro running on latest software. thanks
#3892
Thanks Jim and Randy again for a great Speedo..My RS with 194 full boost 4.31 gear about ran over some cars in the main on a LARGE track running 17.5. No less a very competive feild of cars including 2008 National Champ Justin Lessard (SPX) and others..I had to lift going into sweeper a few times no to run thru some..LOL HP I was far from lacking..Driver I got second, Well I was just short on talent...
#3893
John, When you say a LARGE track what sort of length straight at a guess was it ?
Also at the 4.31 ratio and full boost, are you also running 0 motor timing ?
#3895
hey guys
just started using the RS and the hotwire and i like it alot, on my comp however the buttons are blank until i run the cursor over it??? is that suppose to be like that. . .
#3896
The interface is not the best but it works.
Its too dark, a new brighter skin would be much better.
#3897
This is the first chance I've had to run the lastest verision on my custom PC and I get the same messages that everyone's getting. I didn't try it on my laptop because the original 198 is on it and my custom PC has never seen Tekin before today and won't see it again. Glad I have the old 198 on my laptop and didn't unistall it.
#3899
how hot are your speedos getting mine was 75c today the motor was only 65c!! only noticed when the double sided tape holding the speedo in had stoped holding it in run a fan on it for last 2 runs and was 10c cooler.
#3900
runs good on the pc and laptop.
You can see if the temp is to high with the leds.
