Tekin RS ESC sensored
Thanks Jamie, what is that setting that has c1 and c2 in it? I think it is in the area where you can choose between dual or sensored motors.
I think it is something like throttle profile?.......not sure.
Just checked Rc Market's website(damn that site is slow) and I don't see anything new.
Led's 12 67 means the RS can't read a phase. This can be caused by the ABC motor wires, an open/shorted phase in the motor, or possibly something wrong internally with the esc.
Also on 1s there is one more possible cause. Insufficient BEC/Booster/Rx pack supply voltage.
Any new tekin updates?
Preferrably an update that really takes the trigger dead band away? Min. throttle helps, but it doesn't get rid of it. I noticed that if you set it higher, tires only spin faster as opposed to taking away / minimizing trigger/throttle delay. This is with NW set to minimum.
This weekend the sensor connector broke on my 17.5 Redline and the sensor wire will not stay plugged in. I have a Ballistic 17.5 that I can use while I get the Redline fixed.
I am running 55* boost(5K-20K RPM) and ZERO turbo with the Redline. What is a safe boost setting that I can use with the Ballistic? I was thinking of running the Ballistic at 15* and 40* boost. Would these be close enough that I could get out on the track and test and tune until I have it better.
Yes your mic check has been heard
Looking for some help. I update to 212 from 203 and after about 11 minute of running the car stutters. I would like to reset the speedo to reinstall 212, but I don't know how and I don't know if it will work.
FXR
I found out how to do it and will do today. hope all goes well.
