Associated RC12R5 >
Associated RC12R5
Associated RC12R5
Old 03-18-2012, 04:04 PM
  #3631
Radio Active's Avatar
Originally Posted by sdunnmcp
You cannot go by the manual or shims. Measure the total width of the rear, which should be 172mm. We almost never change this width on the rear of the car. Use whatever shims needed to achieve 172mm.
Steve Dunn
Indianapolis, IN
You say almost never. Out of curiosity what is the rare circumstance you would consider narrowing the rear width?
Radio Active is offline
Old 03-18-2012, 04:10 PM
  #3632
Infinite 12th's Avatar
Originally Posted by Radio Active
What is the rare circumstance you would consider narrowing the rear width?
In extreme low bite to get rear traction
Infinite 12th is offline
Old 03-18-2012, 05:50 PM
  #3633
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Keven Hebert pilots the 12R5.2 to a National Championship in Modified 1/12 scale... AWESOME!
Logi Maker is offline
Old 03-20-2012, 05:38 PM
  #3634
I sometimes run in extremely low traction conditions. (At night on dusty concrete that is used for dog shows during the week.) I hadn't thought to run the rear end narrower, but now I will give it a try. How much narrower is it worth going? Can you explain how narrowing up the rear-end works? There are very few good descriptions of the mechanics of pan car pods.
Old 03-20-2012, 06:42 PM
  #3635
I thought Hebert was running the new prototype?
JamesL_71 is offline
Old 03-21-2012, 07:57 AM
  #3636
I probably should say never but there may be someone that does. I don't know anyone that narrows the rear end for tuning. There are many other things to change first (Dampner Lube, Side Springs, Pod Droop, Center Spring).
For me I am always looking for more rear traction so wider is better.
Steve Dunn
Indianapolis, IN
sdunnmcp is offline
Old 03-21-2012, 01:22 PM
  #3637
valk's Avatar
Thought narrower gave you more traction but wider was more responsive. Or is that only front and touring cars?
When i was asking though was more concerned if the axel would be centered with equal shims on each side. Seems to be though.
Had a revalation this last weekend. Kingpin springs apparently dont last lol. Took em out. Both different lengths i assume after hitting things so one side had more precompression than the other.
One side would turn very sharply and other almost understeering.
valk is offline
Old 03-21-2012, 07:53 PM
  #3638
anybody have a clue where or who has black side springs i cant find them anywhere
Bubonic-X is offline
Old 03-21-2012, 09:05 PM
  #3639
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Looks like Ashford has them
http://ashfordhobby.com/detail.aspx?ID=9315
RedBullFiXX is offline
Old 03-23-2012, 08:50 AM
  #3640
Rick Hohwart's Avatar
Default New setup posted
He was running some prototype parts as were Blackstock and I.
Olly Jefferies clinched the BRCA 1/12 stock (10.5) title with a stock 12R5.1 (with LiPo conversion) this past weekend to sweep the 1/12 championships in both classes.
Olly Jefferies - BRCA Nationals Rd. 6
Rick Hohwart is offline
Old 03-23-2012, 09:29 AM
  #3641
Hi, Try 1 mm at a time and you can only go so narrow because of axle limitations
I think of it like a dragster. They have much rear bite and are very narrow
So we have to balance car handling with rear bite
But if you ever are on really slippery environment it will definitely give you little rear bite/ grip
Also maybe think of width ft and rear and how it will affect rotation of car
Rotation is everything...
Old 03-24-2012, 04:21 AM
  #3642
Hi Rick,
Great news. Is there a 10.5 set-up to go with that Mod one?
Thanks very much for that. I'll give it a go next time I get the chance.
Old 03-24-2012, 08:45 AM
  #3643
RacinJ's Avatar
Do you have any pictures of the prototype parts that you can share?
RacinJ is offline
Old 03-24-2012, 10:15 AM
  #3644
racer x 1's Avatar
Trader Rating: 27 (100%+)
i heard you guys are working on a damper tube set up for the back end? can u comment on this?
racer x 1 is offline
Old 03-26-2012, 08:12 AM
  #3645
Hi Rick,
Apparently same setup for both classes.
No
Yes
