Old 12-10-2008, 05:45 AM   #556
Regional Moderator
Darkseid's Avatar
Originally Posted by Verndog View Post
I had that issue and it was a combination of tweak and tightening the diff that solved it. A loose diff will put more power to one side and make it pull more to one side.
See, I was told to loosen it because it was thought that I was getting tire spin.
Originally Posted by rushrush1 View Post
When you say adjusted the tweek srcews, have you checked the tweek by lifting the front and rear of the car from the center line or used a tweek station to check preload on your tires. Sounds like you have your right rear tire preloaded . Also check the balance of your car.
So I just return the tweak screws to neutral(from what I've seen here...each spring just touching the rear pod), then check the pre-load from there?
The one thing I am sure of is that the side to side balance of the car is dead on.
And heres where I really need help, lets say I do find that I have right rear tire preload as you suggest, which tweak screw should I adjust to remove that problem?
TLR 22...Tamiya F104...
Old 12-10-2008, 09:32 AM   #557
FOXY923's Avatar
Is there a pan car setup guide out there? Anybody have a link? I'm looking for a list of what does what and what changes to make and the order. Something like the XXXmain setup guide.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 12-10-2008, 11:49 AM   #558
Verndog's Avatar
Trader Rating: 16 (100%+)
Place the car on setup board. Put 1 penny on top of each front tire just behind the center of tire. Place an allen driver under the front in the center of chassis (seen by the hole in chassis at C/L). SLowly lift front of car. The first penny to fall off is the tire that is lifting first. Adjust the tweak screw (.050 allen IIRC) on the DIAGONAL rear tire (add spring tension to that side since that corner is compressing first.
Continue until both pennies hit at the same time.
This is the method shown to me from a team racer (not CRC), and it worked great for me......and I have to agree...no setup / tweak instructions makes for some troubled times if you dont have people that know these types of chassis handy. Looks like CRC rushed out the instruction book leaving a very important section missing.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-10-2008, 02:12 PM   #559
Regional Moderator
Darkseid's Avatar
Sounds good. That penny thing is a cool trick, takes the 'eye balling' out of things. I'll give these things a try and hopefully be tracking straight next time out.
Old 12-11-2008, 08:26 AM   #560
Savage6151's Avatar
Hey FOXY try this....might help some....pan car related..
http://richardchang.com/hobby/rctips_112_summary.pdf
FT RC8
O.S. V-spec
Team CRC
Team Associated
Team CFX Paintworks
Sponsors:
G2 Designs....Sick Paint for your RIDE
Troyer25.... Slick Designz
Savage6151 is offline   Reply With Quote
Old 12-11-2008, 08:46 AM   #561
FOXY923's Avatar
RACE 4FUN
Old 12-11-2008, 09:16 PM   #562
s13evo's Avatar
Hi , Got my new Gen10 almost ready. just need a body. heres some picks.
s13evo is offline   Reply With Quote
Old 12-12-2008, 05:19 PM   #563
tell me is the gen x 10 a good car for asphalt
ptjonesus is offline   Reply With Quote
Old 12-12-2008, 05:33 PM   #564
espresso1967's Avatar
Trader Rating: 18 (100%+)
Not sure what you mean? On asphalt track or a parking lot? Works great on outdoors asphalt track. Have not tried bashing on a parking lot but if it's smooth and free from cracks and jumps you should be good.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 12-13-2008, 02:06 AM   #565
thank you I met on a outdoors asphalt track
Old 12-13-2008, 02:21 PM   #566
How does the one piece fit in the gen x 10? Any special modification? Do you have a part number and maybe a pic of your rear one piece?
Thanks for the info
Originally Posted by light View Post
I'm also IROCC and I have found with that body I use Green front springs and Black fronts with White rear springs and Double Pinks it works alright. As for the rear hubs I went with one piece units from IRS
-=light=-
Old 12-13-2008, 02:27 PM   #567
Will consider buying the medium from tbang once I run some test runs and see how it handles first with the HD body. Thanks for the info
Originally Posted by Shawn68z View Post
Yeah I do. Most of IROCC runs the wide kit with the 905B high downforce body. Nice combination. Some drivers find there is to much front downforce with the HD body, and use the medium.
Shawn.
Old 12-13-2008, 04:34 PM   #568
markf3x's Avatar
Originally Posted by Dasmopar View Post
I'm using the light weight diff rings and ceramic Cefx balls and it is silky smooth so far. The thrust bearing looks like a good idea but has a 4mm I.D. and looks to weight about 40lbs. lol
Ceramic balls are very hard, so the contact area between the balls and diff rings is very small.. You can wear in a groove to allow for a larger contact area, which will result in less slipage.
see here:
(scroll down to "building 1/12 scale diff" on the page below)
http://www.markpayneblog.blogspot.com/
markf3x is offline   Reply With Quote
Old 12-13-2008, 08:57 PM   #569
s13evo's Avatar
just finished a yokomo 200mm lola body for the Gen 10.
Old 12-13-2008, 09:11 PM   #570
that looks cool. almost like a 12th scale on steroids.
wait a minute is offline   Reply With Quote
