U.S. Vintage Trans-Am Racing
I have mine on just so it's easier to grid the car, and for practice where we have no turn marshals. Just don't use it during the race! It's cute the first time, but after that, the race director gets a little butt hurt.
I know Losi makes wider hexes (.165, .195, .225) but does anyone make narrower hexes?
Company Representative
You an always Trade/Exchange for either another GTB2, Mongoose or an Edge 2S, which are current USVTA escs:
Trade-In Program
Trade-In Program
I'm looking at possibly replacing my ESC for one known to have strong brakes. My GTB2 brakes are very weak, possibly due to an accidental reversing of polarity the first time it was hooked up to a battery. It seems to work fine otherwise. What ESC's are you all running that have good brakes? Also, how strong are the brakes on other GTB2's out there?
for the guys that have used the GTb2 and the edge speedos - how do they compare to one another??
my gtb2 has served me well for the last year, but would like a little smaller speed control for the my TCX - and was curious if the edge is worth changing over to?
thanks
thanks
As far as trans am goes, it's basically the same speedo. One is just smaller.
I love the Goose, and the Edge is very close with extras...but my GTB2 and Havok Pro are getting it done all the time...if size is an issue...go with the Edge...but it wont be any better than the GTB2...just size
My Mongoose is way better than the origional GTB as the brakes are insane. I love being able to out brake everyone else and dive into a tight corner lock up car sideways and pull the super tight line then blast off. I also run lower gearing than everyone else as our track is very tight.
I think this forum knows I have never raced VTA because it NEVER loads on the first try, i always have to reload.
Just kidding. I have a similar shoe size.
The 4mm ones are roughly .162 or so. I need some smaller than that - like .120-135 (about 3mm). Thank you for the tip on thicker ones.
Same issue here, I think the thread is to long. It thinks the last page is about 4 more than it actually is. When you reload it goes to the correct page number.
The face of the hex would be very thin if you shaved another 1mm off of it as well. You might need to go to something harder than aluminum as I think there wouldn't be enough material left to have any rigidity and you'd end of snapping them along the pin pocket.
If you can find someone with a lathe you could probably rig up a mount/holder and put a 4mm hex on it and turn it down. Would be best to start with solid hexes (not the clamping kind) so you have a completely flat surface to start with. Having the slot of the clamping kind would make turning them a bitch and you'd probably end up breaking or bending them opposite the slot. Any anodizing on the face would be taken off, but it'd be completely covered by the wheel and is only cosmetic anyway.
Search the X-Ray site as well, I think they make them in .5mm increments, but don't know what the thinnest one is.
Good luck.
