U.S. Vintage Trans-Am Racing >
Like Tree1Likes
Old 01-06-2012, 08:41 AM
  #13246
DARKSIDE's Avatar
Default VTA legal battery
Reedy WolfPack 5000mAh 25C 7.4V LiPo Battery
http://www.teamassociated.com/news/l..._LiPo_Battery/
DARKSIDE is offline
Old 01-06-2012, 09:21 AM
  #13247
Originally Posted by SWTour
Generally the point of the MINIMUM HEIGHT is to protect the track surface, and to keep from cutting surface mounted scoring loop wires.
In that scenario, the body AND chassis needs to clear the "MIN HEIGHT" tool.
Generally when under power, and under load the car will drop. so if anything is lower than the 5mm or what ever the min. height is, there is a good chance it will drag or scrape the surface.
I have to disagree. Ride height should be the height the chassis rides with the body on. Not how low the body hangs. If a 5 mm ride height is necessary to protect a track then why are f1 cars and 1/12 cars slammed down to the deck? We all know that rubbing a body is not good for speed or handling and the track owner can ask that a body be raised to prevent rubbing and to protect the surface.
As far as weight shift I have seen many cars at a 6 mm or greater height with light springs and thin oil that still hit the track.
6376vette is offline
Old 01-06-2012, 10:16 AM
  #13248
Originally Posted by robk
+1
Ride height question was previously answered by RobK see above
ebruce is offline
Old 01-06-2012, 10:18 AM
  #13249
Usually, all parts of the car would be subject to a 5mm minimum. All points of the chassis and body.
+1
Ride height question was previously answered by RobK see above - Appears on P615
ebruce is offline
Old 01-06-2012, 10:23 AM
  #13250
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I run in the SWT series. Ride height is checked with the body on.
Trust me, you can clear the 5mm ride height gauge and still drag the body in 1/10 carpet oval. The ride height gauge is simply to keep, ummm, less attentive racers from ruining the track.
CraigMBA is offline
Old 01-06-2012, 12:17 PM
  #13251
Meradin's Avatar
Trader Rating: 19 (100%+)
Page numbers don't mean anything as you can change the number of posts per page. There are only 327 pages in my view format. Post number is much better.
I would love to read the context of that discussion if you could point me to the post.
I do know that ride height NEEDS to be determined with the body on. Many of the local racers need the weight of the body in order to make minimum, myself included. I need to add weight and opted to shoo goo the crap out of my body to add weight and support rather than just add weight to the chasis.
My original question still is unclear. Is ride height determined from the lowest point, body spoilers included? I am inclined to say yes, but I would love to hear from the USVTA on the matter (So i can pass the blame!)
Meradin is offline
Old 01-06-2012, 12:35 PM
  #13252
I asked the question in post 9214, brief discussion, then RobK confirmed that it is 5mm to the lowest point on the car, body parts included, post 9217
ebruce is offline
Old 01-06-2012, 01:17 PM
  #13253
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by rocketron
Originally Posted by wwddww34
Here is a page right out of the ROAR Rule Book for the VTA Class. Keep in mind that for the 2012 Carpet Nationals race, the motor requirement will be changed to 25.5 Turn brushless motors only.
Just a note to let the VTA class racers know that these rules are NOT the final version for the 2012 Carpet Nationals.
I am currently working with several different people who race this class and will have updated rules very soon - very soon. ROBK is one of those key people.
At the moment I see no reason why ROAR's rule should vary from a successful and established class.
Thank you Ron and RobK for all the work you are doing. I am the happiest kid on the block just because there will be a VTA race at the ROAR Carpet Nationals.
wwddww34 is offline
Old 01-06-2012, 08:59 PM
  #13254
Guess I need to raise my body. Thanks for the official clarification... Now I have to mess with the roll center to compensate for the higher cg. Good thing I enjoy the tuning as much as the racing
Old 01-06-2012, 09:16 PM
  #13255
robk's Avatar
Any time ride height is checked in tech inspection NO PART of the car, body, battery, screws etc. can be lower than 5mm. That is the point of a ride height rule.
The reason pan cars and 1/12 are 3mm is that the suspension movement is miniscule compared to a touring car.
robk is offline
Old 01-06-2012, 09:21 PM
  #13256
DARKSIDE's Avatar
sounds fair to me
DARKSIDE is offline
Old 01-07-2012, 06:11 AM
  #13257
Originally Posted by DARKSIDE
sounds fair to me
Me too. That's why I like this class. No grey area on the rules. Makes it a lot more fun.
Old 01-07-2012, 09:28 AM
  #13258
IndyHobbies.com's Avatar
Ditto!
IndyHobbies.com is offline
Old 01-07-2012, 08:55 PM
  #13259
jayh50's Avatar
Default Big club race
Wow! We had 91 racers at our club race tonight! 11 VTA! It was AWESOME!
jayh50 is offline
Old 01-08-2012, 06:30 PM
  #13260
I would like to get into vta racing, and I see they do it at my local track, any suggestions on a good place to start? As in chassis or which ever?
Jarrad is offline
