Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 02-12-2009, 08:44 PM
  #4396
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I just built and raced the 416WE this past weekend, car handled awsome! I did notice last night as I was cleaning the car and checking tweak and other maintenance, that the front belt had been rubbing on the chassis. I was thinking of filling the chassis a little but decided to tighten the belt just one notch, after driving the car around today it still rubs Anybody ever ran into this situation before? I'm just going to file the chassis, what do you think?
bigkoitat is offline
Old 02-12-2009, 11:02 PM
  #4397
RC MARKET's Avatar
Originally Posted by gansei
Best Lap Time:
- LTC-R Body with Much-More AT 32 tire => 7.25 sec.
- TITAN Mazda6 Body with Much-More QTS 32 tire => 7.301 sec.
i felt aggressive feeling with LTC-R Body.. and stablility with Titan MAZDA 6.
good , but isn't same tire
RC MARKET is offline
Old 02-13-2009, 12:31 AM
  #4398
sakaguchinet's Avatar
Hi,
my absolute favourite is the Protoform Mazda Speed 6. If I need a little bit more steering I prefer the old Mazda 6 (without Speed!)
btw: All the TRF416WE Spare Parts finally arrived and are available here: http://www.sakaguchinetshop.com/inde..._TRF416WE.html
sakaguchinet is offline
Old 02-13-2009, 04:10 AM
  #4399
TryHard's Avatar
In agreement with the belt tension comment... loose is fast... making it tight will just add unwanted amounts of drag to the driveline. You want it as loose as possible without the belt skipping on the pulleys.
Don't forget we have the bearings mounted off the top deck, they aren't a tensior per-se, more there to help reduce the belt vibration, mine hardly touch the belt at all.
If you want instant response, you need to go with a shaftie
As for the belt rubbing, I guess it's at the front under the pulley? just file the chassis back at an angle to clear the belt better
Cheers
Ed
TryHard is offline
Old 02-13-2009, 08:49 AM
  #4400
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by kschu
hi Randy, how ya doing ?
Good, how have you been?
Randy Caster is offline
Old 02-13-2009, 08:52 AM
  #4401
Honestly you're not going to hurt anything by the belt rubbing on the chassis, even if you file the chassis down there will still be times where it's going to rub, just like John said, it's going so fast there's really no way to stop it. Try lowering the roller bearings on your top deck a bit, that may help with some of the belt stretch under power.
Old 02-13-2009, 09:49 AM
  #4402
Hebiki's Avatar
Trader Rating: 26 (100%+)
Cheers
Ed
waiting for my Evo5 MS
Hebiki is offline
Old 02-13-2009, 11:11 AM
  #4403
bigkoitat's Avatar
I never noticed anything like you guys said, if anything the car drive train is the smoothest hands down. Super quiet and bind free I just set the tension like the manual said and later tightened the front one notch. Honestly though I really could'nt tell a difference. I just need to buy a new ESC now since I F-upped my SP this weekend
Old 02-13-2009, 11:26 AM
  #4404
I have a speed passion GT v1.1 for sale if ud like .
John St.Amant is offline
Old 02-13-2009, 11:40 AM
  #4405
jonny123's Avatar
Default Bodyshells
hi
what motor were u running in that car you did the testing the bodyshells with it was rapid and the motor sounded crazy fast. By the way the car looked dialed with all shells but the ltc looked the best.
jonny123 is offline
Old 02-13-2009, 11:51 AM
  #4406
STLNLST's Avatar
Trader Rating: 32 (100%+)
This may be personal opinion but I have yet to see a drive train smoother than the Xpress Mike Swauger Edition. That was so free back in the day. I know Billy Bowerman still has one. Maybe he could set up a fun little test between cars if he has extra time....
STLNLST is offline
Old 02-13-2009, 03:01 PM
  #4407
JimmyMac's Avatar
You my friend suck once again! haha When you get it, send it to me!! Actually, I'm thinking of revamping my Evo IV. I want to put 416 steering on it. Plus did you know that 416 shock towers are a direct bolt on!!! I'm hoping that the counter sunk shock towers will help some with chassis tweak. I also think the high top deck will be good to clear the pinion for 17.5 and 13.5 classes. Plus I have Evo IV spools! 416 suspension bolted up... should be a nice car. Just too bad it won't be TCS legal since it'll be a 416/Evo hybrid. But I can always club race and Roar race it. Anyways, lemme know how you like the Vms.
JimmyMac is offline
Old 02-13-2009, 03:23 PM
  #4408
veecee's Avatar
Trader Rating: 34 (100%+)
Best Lap Time:
Thanks for the videos. The LTC-R looks very good around the track. It looks like the Speed 6 pushes more so you tried to compensate with your driving but made more mistakes. Was that how it fely?
veecee is offline
Old 02-13-2009, 04:24 PM
  #4409
tboned_2002's Avatar
Good Call Clint, that car had its pro's and cons. Down in the "OC" Ultimate is still selling them for 80-100 bucks.
tboned_2002 is offline
Old 02-13-2009, 05:09 PM
  #4410
STLNLST's Avatar
Can I get a little help from some of you longtime Tamiya guys? Tower hobbies has Tamiya parts but I'm having the hardest time trying to locate a couple of parts. I tried searching using the Tamiya part number but nothing comes up. Lokking through a couple of pages I didn't see them. I'm trying to order the following items.
TAM53572- 2hole piston
TAM51065- 1B pivot block
TAM53932- 0.5 shims
TAM53933- 1mm shims
If tower doesn't carry these is there somewhere stateside that I could order these from? Speedtech is out of stock on some of these items. Thanks for any help you can give me
STLNLST is offline
