Tamiya TRF416 / TRF416WE / TRF416X
#4426
Make slugs to fit the battery holes in the chassis.
Glue them to the battery. They will also help keep the pack in place.
I highly recomend brass. But tungsten is heavier. You are going to need approximately 110 grams to get it up to weight depending on what electronics you are using. Try to keep the bottom of the chassis smooth and the weight low.
#4427
I always run it outdoors with my 10.5, but I'd be interested to know how a motor temps with and without it at the same gearing. I was told by a friend that it makes about a 20 degree difference, so that would let you gear up around 2 extra teeth on the pinion compared to running without the fan. I'm getting a new speedo and motor this week so I might do some testing when they arrive
#4428
Get a 5000mah 40c battery.. About 300 grams worth of batteries.
#4429
then i distribute the remaining weight i need to add evenly around the car.
so for example.. if im 28grams short.. ill take 4 pieces of lead weight that is 7grams each.. put two in the rear...two in the front.
also, if your battery is significantly lighter than your electronics side... try getting this:
http://www.ppdbillet.com/RC_accessories.html
there are two small areas you need to dremel (for the motor mount brace and servo holder)...and it fits like a glove underneath your battery.
#4430
#4431
#4432
what i do to balance my car is... i weigh all my electronics... then weigh my battery. i add weight to the side that is lighter.
Looks great there, where can we get one??? But lipo nowadays come with groove...
#4433
#4434
#4436
I've been running the LRP stock spec 10.5, which is pretty torquey but doesn't have the RPM of the novak, so I normally find myself quickest when geared up as it has the torque to pull through the infield with a tall ratio. I believe my novak and spx speedo arrived so I'll be gearing right down, and if I can achieve similar top end without having to cop the weight of the fan on the ESC side I'll be
#4437
My Trf 416 WE NEW MACHINE!!!
#4438
I finally got the 416 dialed in, the car handles amazing!!! In the final this weekend I was doing really good but half way through the race I noticed the car handling weird
earlier in the day the Steering post screw backed out and was not letting the car to compress, I fixed that and lock-tighted all the other bottom screws. but in the final "3" top deck screws in the rear section almost backed all the way out. I'm a pretty strong guy and sometimes over tighten screws, I think with the added flex it caused the screws to work its way loose. I've since put loc-tite on all the screws on the car(blue loc-tite) so this never happens again. can't wait till next race and drive the car again
#4439
Just want to share my joy with you guys. I TQed and won the A main driving this car during. It was my first electric TC race in an indoor carpet track with control tyres. The car was spot on from the very first I drove it. I m the only one driving a Tamiya in the A main which surrounded by XRay T2009 and yet I won. I m really loving this car.
#4440
Do other people have issues with the steering alignment going out in even small bumps? Whenever I tag a barrier, I often have to give my trim a couple of clicks to get the car to go straight again. I thought it might have been the servo saver so switched to the square alloy insert, so now its either the servo or radio, or it's the ackerman screws bending slightly
