Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 12-14-2008, 08:46 AM
  #3646
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I went out to the Tamiya USA track for some practice yesterday. I put Hupo's Reedy Race setup on my car and it was dialed. Easy to drive but with plenty of steering and grip, definately worth a shot for anyone on a fairly large medium grip asphalt track.
The only difference from the setup is I threw on a set of the Much More premounted 36 tires. And since the setup doesn't list a body I used a Mazda 6.
Randy Caster is offline
Old 12-14-2008, 09:04 AM
  #3647
ali_g's Avatar
Originally Posted by Adam?
I've been struggling a bit (13.5, rubber tire, carpet) with a spool and one-way being too aggressive (for different reasons) and a diff being too soft out of the turns. I decided to try a spool with a center one-way, and it felt really good. Kind of like a very mild one-way... or a very mild spool. Hard to explain really.
So, is this configuration unheard of? I never really quite understood the point of a center one-way to begin with, but figured I'd pick one up to see how it felt with a diff. I was surprised it felt any different than a regular one-way (when combined with a spool) to be honest, but it definitely did.
Adam, i heard of this config b4 but yet to try it, from what i heard its a much stable oneway.
ali_g is offline
Old 12-14-2008, 09:06 AM
  #3648
ali_g's Avatar
hi guys, anyone did a comparison between the 416 and 416WE before?
ali_g is offline
Old 12-14-2008, 09:33 AM
  #3649
Low_E's Avatar
any link to this Hupo Reedy setup?
Low_E is offline
Old 12-14-2008, 11:13 AM
  #3650
Jimmy Jacobson's Avatar
Hupos Reedy setup is somewhere on this thread sometime in June or July Pretty much all the Tamiya drivers ran the same setup
Jimmy Jacobson is offline
Old 12-14-2008, 11:17 AM
  #3651
TryHard's website has a ton of setup sheets listed, thats where I found it.
Old 12-14-2008, 11:39 AM
  #3652
danjoy25's Avatar
Trader Rating: 38 (100%+)
How do you guys measure droop? Im thinking of trying the different setup in Ed's site as well. In Hupo's set up, his running #6mm front and #5mm rear droop. Just want to make sure Im measuring the same as per setup sheet. Everything else I can follow except this. Thanks in advance.
danjoy25 is offline
Old 12-14-2008, 12:04 PM
  #3653
Picking a spot under the arm is crutial. making it easy to read and fit the guage under whatever happens to be sticking from under the car . Typically I believe the simplest way to measure it is under the outer hinge pin an front of the lower control arm. Some ppl do it by lifting the car and looking at the amount you life before the tires.. (sorry, tyres) w come off the surface. Thats most likely good for foam but not I think accurate enough for rubber. I set mine as previously stated and 6/4 f/r is what i like on the carpet.. so far .
John St.Amant is offline
Old 12-14-2008, 12:10 PM
  #3654
danjoy25's Avatar
Thats the bit that is confusing. I hope the setup sheet includes which spot the droop was measured.
danjoy25 is offline
Old 12-14-2008, 12:50 PM
  #3655
Usually under the outer hinge pin, at the bottom of the A-arm.
Old 12-14-2008, 01:31 PM
  #3656
Adam?'s Avatar
Corey Whiteman,
Mind sharing your setup from the GrandSlam race?
Adam? is offline
Old 12-14-2008, 01:50 PM
  #3657
danjoy25's Avatar
So is the pic below correct if the set up sheet says 5mm rear droop.
danjoy25 is offline
Old 12-14-2008, 02:33 PM
  #3658
TryHard's Avatar
yup, spot on Most setups quote ir like you say, with 5mm and 4mm... whats slightly confusing is that a smaller number actually equates to more droop...
The most accurate way of measuring droop is actually to remove the wheels and tyres, then place the car on a flat plate and measure up to the axles. This way you can keep it consistent from tyre to tyre (they all have slightly different diameters)... and is good for Foam.
David Junn explains the method in more detail here http://www.thard.co.uk/415/tips/DavidJundroopmethod.doc
HiH
Ed
TryHard is offline
Old 12-14-2008, 03:26 PM
  #3659
Default re
Hey Adam,
here is my setup fresh from the Grandslam race at fastcats.
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-416-grandslam-race-2.jpg
TRFwhitey is offline
Old 12-14-2008, 03:27 PM
  #3660
I found measuring droop at the axels difficult . But if all you have is a caliper with a depth guage I suppose that works. But more ideal would be with the droop guage and support blocks. and w/o sway bars ...
