Old 10-17-2008, 11:44 AM   #3016
Adam?'s Avatar
This will undoubtedly sound pretty dumb, but...
If you're using one of the Square lower bumpers, keep an eye on it and make sure it's not rubbing on the racing surface. They tend to bend downward with use and impacts, and will eventually begin to rub. If your car stops turning after a front impact, this could be the culprit. :-)
Adam? is offline   Reply With Quote
Old 10-17-2008, 05:13 PM   #3017
Vicko's Avatar
Trader Rating: 14 (100%+)
so dose anyone have the carpet set up for Vages for the 416???
anyone???
Vicko is offline   Reply With Quote
Old 10-18-2008, 12:49 AM   #3018
Low_E's Avatar
Send a message via MSN to Low_E
I have bought a second hand 416. The previous owner has made the conversion to the shorter A-arms and has build it with the Jilles groskamp-setup.
He has never driven the car and sold it with a lot of parts ... my luck.
However, ... this is my first Carbon-chassis-car and I still have a lot to learn.
So I was considering to rebuild the car to a more standard set-up, just to have a good start from there, as I am far from an experienced driver-mechanic and have a lot to learn on how to tune a car.
I will be competing in stock-competitions (27T-motors) on carpet track with medium grip so I thought the car would better equiped with the One-way. I prefer driving a One-way over a direct coupling (which we seem to call a spool over here).
Should I start with the manual-setup? Or is there a (short-Arms) set-up that will be a better as starting position?
I 've lookd into the set-up-section on http://www.thard.co.uk/ and found the setup from Chris Vanderhagen, which also uses a One-way for his 19T-setup.
Would this be a not-so-critical set-up, good to start with?
A friend of mine (Grooveman), with loads of experience told me I'd better begin with the manual-setup, so I will follow his advice, but it would be nice to have a back-up plan (as this friend is not always arround when tuning my car ) and since I have the parts for the short-arms-conversion anyway?
So ... all advice much appreciated!
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 10-18-2008, 06:05 AM   #3019
HI_808's Avatar
Mostly likely, you will be unhappy with the manual set up and end up needing to make a number of changes. You have to understand what the changes you make will do to the car in order to make it handle better. So, if you are most concerned with learning, then I'd say to go with the manual setup.
HI_808 is offline   Reply With Quote
Old 10-18-2008, 11:53 AM   #3020
Super Moderator
Grizzbob's Avatar
In general I'd agree, hoiwever, I'm always willing to try a car the way it is, if I were you, I'd at least try it with the short-arm setup first & see how you like it(you never know, it might suit you), & be prepared to go long-arm if you feel it neccessary....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-18-2008, 01:14 PM   #3021
Low_E's Avatar
mmm, ok, but WHAT short-Arms-set-up should I use then, as a starting point.
Old 10-18-2008, 01:48 PM   #3022
auzzy_mate's Avatar
Originally Posted by quantum View Post
the tray looks good... do you have any pics of it installed?
These are some pics of a LiPo tray installed in my 416.
Ben
Tamiya TRF416 / TRF416WE / TRF416X-tray1.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray2.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray3.jpg   Tamiya TRF416 / TRF416WE / TRF416X-tray4.jpg
auzzy_mate is offline   Reply With Quote
Old 10-18-2008, 06:44 PM   #3023
sohlman's Avatar
Trader Rating: 89 (100%+)
Try starting here. It's been working for me for a while. I'm using the 2.5 chassis, but the 2.25 is pretty close. Hope this helps.
Tamiya TRF416 / TRF416WE / TRF416X-trf416_101008_360.jpg
Steve Sohl
sohlman is offline   Reply With Quote
Old 10-18-2008, 10:12 PM   #3024
CraigM's Avatar
Trader Rating: 34 (100%+)
That is a very solid setup to start with. I would stick to the 4mm hex hub up front and no wheel spacer though as D/D with the 5mm hub will be a wider track than XA/E at the rear. Also if it's too steery go back to 3mm of ackerman
Edit: just saw the 60/50 oil split which explains the ackerman. 50/50 with the 3mm ackerman would also work pretty well
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-19-2008, 01:03 AM   #3025
Low_E's Avatar
Sohlman, CraigM, thx guys,
I've been asking these questions on different fora. You guys are the first to give me some useful, to-the-point answers
I will definitely try this set-up as a starting point.
but as I am still learning ... could you explain me how one can change ackerman? I am not able to find anything about "ackermann" o the set-up-sheet but I guess, if I learned correctly, this is done by switching the steering rod-connection to a different hole on the steering block?
About "5mm hex hub". I only have the standard 4mm Hex wheel hubs. I guess I could use those and add a spacer? ... Or just use the 4mm, as CraigM says
Also, I learned from some veteran tamiya-racers, that the Tamiya-shocks should be 62mm long, so I always build them that way on my previous TA05. Why did you choose to make them 61.5mm? Does it make a (big) difference?
And then I have yet another question. The building manual mentions you should not spray the belts with some products. But somewhere else I've read that it helps to spray some WD40 on a cloth and to wipe the belts with it and that it helps to smoothing the belts.
My belts are brand new. I thougt it might help to loosen them up or is it something that has to be avoided?
@ Sohlman:
How did you add the extra weight on the Lipo? As a lead sheet on top of the Lipo?
Did you use some more lead or weight in other positions on the chassis?
What brand of oil were you using? Was it Losi oil?
and ... if I might still add these questions
Do you have this set-up-sheet also in a greater resolution?
How do you make this (very clear) digital set-up-sheets?
Again, THX! for previous advice ...
and thx in advance for helping me out with my other questions.
Old 10-19-2008, 01:05 AM   #3026
berserk's Avatar
Default rear toe settings
Good day!
I have a question regarding rear toe settings. I am running my car on a tight and technical track with a short straight. I would like to ask which settings will suit best on this kind of track, a rear toe in of 3.0 deg or 2.5 deg?
thanks!
berserk is offline   Reply With Quote
Old 10-19-2008, 06:06 AM   #3027
sohlman's Avatar
@ Sohlman:
I use a PPD EZ-Lipo battery tray (www.ppdbillet.com) with lead weight strips on the side (see the orange blocks on set up sheet). I also added 15 gr extra to balance it left-to-right. I use Trinity shock oil. The set up sheet was created and modified in Illustrator CS3. I'll post a larger version in a little while.
Steve Sohl
Old 10-19-2008, 01:22 PM   #3028
Low_E's Avatar
and how do you attach this lipo-tray into the 416? With tape?
Old 10-19-2008, 01:56 PM   #3029
sohlman's Avatar
Steve Sohl
Old 10-19-2008, 04:43 PM   #3030
CraigM's Avatar
Low_E, ackerman is best adjusted by adding or removing spacers from the inner steering rod ball mounts. More spacers = greater ackerman effect. You can change where the balls are on the knuckle but from what I've heard there is a huge difference between the two holes, plus I've never seen any setups using the front one - my square knuckles have a 3rd hole inbetween but I've never tried that either. Don't spray anything on your belts either, I've had my car for months now and I'm still on the original belts, I just put them in and went racing.
Beserk is your track carpet or asphalt? I'd start with 3 degrees and go from there, I race on a pretty tight asphalt track and 3 degrees is just right
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
