Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-30-2008, 12:16 PM
  #2266
TryHard's Avatar
Originally Posted by jontang001
Wo!!!Thanks Ed!!!
I always talk to my friend that no one use a one way outdoor....
I need to say sorry to him...he is a one way guy...
But, I hear about to use spool when low traction...is that right?
According to your post...spool allow a driver to miss a little bit but one way need a very stable driving style....is that right?
But, two week ago, in our last carpt race, I was use your 415MSXX stock setting for a 10.5R race...and that was awesome!!! I only changed rear toe in to 3 degree. I got A3 at the final and A3 finished. The car was still under control...my be last time I will change to 416 (if I got some spares...) and spool for carpet this winter.
So thanks Ed...for your fantastic website and awesome settings....WO!!!
Not a problem. What axle works best for you is really for you to decide. At the end of the day its what your comfortable using. I've used different combinations for different surfaces before, a lot of it does depend on the track type.
NiH
Ed
Writer from my iTouch.... hehe
TryHard is offline
Old 05-30-2008, 08:02 PM
  #2267
Default Spool
Hello all,
I agreed with what tryhard have said. BTW, I race 23T, in asphalt that have medium to low traction. I used spool in front with center one way. I feels that it give the best compromise between one way and spool, where you can have a more stable car yet still can brake. Please correct me if I am wrong.
Originally Posted by TryHard
A lot of that depends on class, track type, surface... but some general rules I tend to go on.
A one-way is usually faster over one lap, but is generally restricted to one line, and you loose the use of brakes (unless your really good ). A spool maybe slightly slower over a single lap, but can be more consistent over a run, as it's not restricted to one racing line. It also allows the use of brakes.
Outdoors, I'll use a spool in all classes, unless the track is particularly wide and open, and the I may consider a one-way for steering (this is especially so on big tracks with slower classes).
Indoors, mod and 10.5/19 I'll go spool, whilst stock I'll always tend to use a one-way. (although I did use a spool last time out, but that was beacuse I'm lazy...)
HiH
Ed
teamB is offline
Old 05-31-2008, 10:49 AM
  #2268
HappyHippo's Avatar
Any one know where I can get a chassis now at days, tryed most of the internet shops i the east and USA, but no one has in stock
HappyHippo is offline
Old 05-31-2008, 11:13 AM
  #2269
RC MARKET's Avatar
Asia out of stock !
RC MARKET is offline
Old 05-31-2008, 11:28 AM
  #2270
HappyHippo's Avatar
Originally Posted by RC MARKET
Asia out of stock !
I know do you know when the new chassis wil be in stock
Old 05-31-2008, 03:19 PM
  #2271
Gone Racin's Avatar
Default 416
Hello Racers, Try MUCH HOBBIES.com i think they have them. Ron H,
Gone Racin is offline
Old 05-31-2008, 11:59 PM
  #2272
sakaguchinet's Avatar
Hi,
regarding the worldwide TRF416-no stock topic: It like the iPhone from apple... But still waiting for the "WWDC" from Tamiya.
By the way: The 42106 TRF416 was a limited item (because of the 42xxx number). The first TRF415 was a normal item (because of the 58xxx number).
Finally the new aluminum rear hubs are available. Also the servosaver from aluminum, which got very popular in the 416, is also available now.
STV-44MS Rear Hubs 0
TGE-22xx Servosaver for Hight-Torque Servosaver
sakaguchinet is offline
Old 06-01-2008, 01:22 AM
  #2273
Rogier's Avatar
I've spent 2 days lately on searching an in stock 416. No where! But when I used Google I ended up at 2 stores. Vellrip.com and another one. I bought mine at vellrip.com, but it was the last one. Try Google as well, the store who had a 416 in stock as well was standing on the 2 resultpage in think. Good luck! I'm just building the 416 and it's awesome!! I can't find any good reason why I switched over to the S400 earlier this year. I'm VERY happy I'm back at Tamiya! No switches for me anymore!!
Rogier is offline
Old 06-01-2008, 03:23 AM
  #2274
Tamiya USA has the 416 lower deck chassis in stock.
http://www.tamiyausa.com/product/ite...uct-id=9404856
Solid G is offline
Old 06-01-2008, 11:13 AM
  #2275
RC MARKET's Avatar
lower deck had stock !
but not have kit !
Old 06-01-2008, 11:16 AM
  #2276
pug 205 gti's Avatar
RCMARKET when are tamiya going to release more trf416 kits.
pug 205 gti is offline
Old 06-01-2008, 11:23 AM
  #2277
RC MARKET's Avatar
Old 06-01-2008, 01:57 PM
  #2278
adrictan's Avatar
http://www.etamiya.com/shop/product_...ts_id=10001645
adrictan is offline
Old 06-01-2008, 03:34 PM
  #2279
Hebiki's Avatar
Trader Rating: 26 (100%+)
$499??? no thanks.
Hebiki is offline
Old 06-01-2008, 05:07 PM
  #2280
CraigM's Avatar
Trader Rating: 34 (100%+)
What effect does raising the height of the rear camber link have? I've noticed on high grip tracks (e.g. @ TITC) most of the setups have spacers under both sides of the camber link whereas the reedy race setups for medium grip have the links lower but still at the same angle. I also noticed Victor's reedy set up has less spacers under the inside front link compared to his TITC but this is probably to couter using hole 1 to mount the suspension on the arm
CraigM is offline
