GM Brushless
#901
He has already a new sensor wire but we will try to reset it tomorrow again.
thanks for the help.
I let him try an other sensor wire.
I will let you now if it worked.
#902
read the stock how-to and try to set it up like that
#903
Hi all,
I have been running a 6.5 star wind with mode 8 copied over mode 3 for a while now, but this weekend I had issues with 'cogging'... sometimes it would be fine, but other times I'd need someone to push the car to get it rolling.
I factory reset the controller and tried 3 different sensor cables. It was better when running without a sensor cable sometimes.
I have two motors (both star 6.5) and this has only happened to one of them.
Any ideas on what I can check ?
When I copy 8 over 3, the only thing I change is the initial brake (put it to 40 instead of 20)
The one that has this 'cogging' problem gets hotter than the other one, and I found that I couldn't gear them the same on the same track (same car)
I had an FDR of 6.2 on the other one, but couldn't go much below 7.3 with this one. (temps 80c-85c)
Any suggestions welcome.
#905
sensors broken
#906
Chris,
You can get replacement sensor boards, check the Graupner site for the part No.
Also check the solder joints between the socket and the board go over them with a small iron it might fix the problem these are know to go occasionally.
Jason
Jason
#907
That's a bit disappointing as it was a brand new motor (first run was Saturday and it did it from the start)
I might have a sensor sitting around somewhere at home...
thanks for the info guys
#908
Few Cosmetic problems.
Hi martin, the sticker on my 120 is all pealing . Will i void the warrenty if i peal it off? Can you get new stickers?
Also i have the found the removable reciever wires a little weak. Especially the short black one. Its really stiff and the wires snap where it goes into the esc. Ive ordered a standard one so ill see how that goes.
Also, does the aluminium case cause interference if too close to the reciever?
Thanks in advance.
-Jonny
Thanks in advance.
-Jonny
#909
Jason
#910
I did try shimming the rotor slightly towards the sensor on the day, but that didn't solve it
#911
Hey Chris what is the motor that you are having probs with?
I have probs running the X12's with GM speedo due to the amount of advanced timing already in the motors, they occasionally cog if I don't set the soft start high enough and they overheat even when undergeared.
Paul Pinkney
Paul Pinkney
#912
Paul Pinkney
Paul Pinkney
#913
Chris - Not sure i'd admit to that one!!!
#914
hehe, i've still got loads to learn
#915
Thanks in advance.
-Jonny
Thanks in advance.
-Jonny
I never experienced interference caused by the speedo...
Paul Pinkney
Paul Pinkney
but if you don'T have to use the X12 why should you :-P
