spektrum in a m8 glitching and shuttinf off >
Old 02-13-2007, 02:27 PM
yeaklet4's Avatar
Trader Rating: 34 (97%+)
Default spektrum in a m8 glitching and shuttinf off
ok i have a futaba ver 1 esc same as the lrp comp1 and a air 94157 servo the rx shuts off and glitches bad. i tried differnt servos and same thing. but i tride a differnt esc and it works great. when using the futaba esc you can see the light on the rx like blinking and then shuts off. what do i do i realy like that esc.
yeaklet4 is offline
Old 02-13-2007, 03:35 PM
Try the external capacitor for the Spektrum reciever. Some ESCs have too low of a voltage output to work well with the Spektrum recievers, especially in cases of weak batteries or 4 cell. Running the capacitor or a reciever battery pack usually takes care of it.
InspGadgt is offline
Old 02-14-2007, 08:04 AM
RCGaryK's Avatar
Also, if you have the ability to increase the BEC voltage that would help as well. Run both a power cap on the ESC and use the SPM1600 Voltage protector and you should see the problem eliminated. Also, if you have had your receiver since before May of last year, it wouldn't hurt to send it in for a Free firmware upgrade too.
RCGaryK is offline
Old 02-14-2007, 09:48 AM
yeaklet4's Avatar
how do you change the bec voltage i did not know that some you could change?
yeaklet4 is offline
Old 02-14-2007, 01:14 PM
RCGaryK's Avatar
I'm not sure if you can with the Futaba, check your manual. I believe on the Keyance and I know on the KO VFS-1 you have the ability to do this.
RCGaryK is offline
Old 02-14-2007, 01:46 PM
schmelme's Avatar
Run the capacitor with any lrp or just junk it and get a novak LOL
schmelme is offline
Old 02-15-2007, 01:44 PM
Hey I nkow this is off the subject but can anyone tell me how to get a copy of the operators manual for an M8?
NUCRPTRACER is offline
Old 02-15-2007, 02:17 PM
bukil's Avatar
Trader Rating: 39 (100%+)
Click here.
bukil is offline
Old 02-17-2007, 08:57 PM
bozla's Avatar
You havenīt left the fast response button on or something have you? Futaba and sanwa fast response wonīt mix.
bozla is offline
Old 02-17-2007, 09:57 PM
yeaklet4's Avatar
yes the response is on but i put on the cap and it seemed to fix the problem
yeaklet4 is offline
