Alex Racing Barracuda R2 & R3
#3691
R/C Tech Elite Member
Originally posted by JDM_DOHC_SiR
I just count the coils on the spring...it`s not that hard to do and since I only ise 1.5 dia.,,it`s awalkin the park
-Dave
-Dave
#3693
Regional Moderator
Originally posted by Randman
You wouldn't happen to have a scan of the little sheet that comes with the springs with all the different weights do you? I'm trying to figure out what to order...
#3695
use the one on the right and it`s the middle chart with the 1.4 and 1.5
-Dave
#3697
Regional Moderator
You're a lifesaver Joseph
#3698
Click here and look at the pic`s
-Dave
-Dave
#3699
Does Saturday have a brushless class? I got this Sat off
or we get grouped in mod if the travelling guys are back in town. either way we can run nearly all day testing setups
#3702
Xenon Chassis Kit
OK Guys...
Here is the Skinny on the Xenon chassis kit..there will be 3 types..and they will have the 3mm chassis like the PAL one..and it will be milled down 1mm ..ect ect... the colors will be the same as the PAL version but the batterys will be on the Same side as the R2(normal)
the 1st version will be the upper deck lower deck and motor mount ..only.
the 2nd version will be the upper deck lower deck and dog bone drive shaft and front and rear drive cups..
and the 3rd version will have all the above and they will include a full set of Xenon Hubs front and rear to match the car,,
also should have a slightly different upper deck than the PAL version..also the lower chassis wil be a little different too..
the Price should be a tad bit better than the PAL version too...I`ll have my kit on the 2nd of September...so I`ll post some pic`s for you all then
with the PAL chasi to follow about a week later.
-Dave
-Dave
#3705
Re: Xenon Chassis Kit
OK Guys...
-Dave
OK Guys...
-Dave
why would they sell it without the drive cups, etc. ? or do the original PAL system bits work?
hmm.... what to do....
