Yokomo MR-4TC SD
What do you guys think of the sd cgm? Is it still worth getting? Seems like not many is running the cgm chassis. Please advice.. thanks.
Like most thing's manufactures do not sit still and always develope new cars like the LCG(shaft)and BD(belt), both have twin deck C/F and same geometry setup. where as the CGM is a tub chassis and a little on the heavy side.
So if you like tub go CGM, if you like twin deck but stilll shaft drive go LCG and lastly if you like Belt go BD. a lot of spares can be used on all three cars
You can probably get a very good, cheap CGM on ebay.
HTH
adyb
Thanks for sharing
Thanks for sharing
how can i achieve less steering going into a corner and more steering coming out of the corner
i was lifting my inside rear wheel in a high speed chicane and diffing out. i added more rear droop and installed a thin rear sway bar. . sound like a good idea ?
reduce rear droop as shorter shocks as in if im running 3mm of rear drop i should try 4mm ?
Man, I hate talking about droop. Droop gauges make it confusing as well. The best way to decribe it if using a droop gauge, is say about 6mm in the front and 4mm in the back. The point is to reduce the amount of suspenson travel in the rear, compaired to the front. On carpet (foams) I like about 2mm of suspension travel (front) before the tires lift off the ground. And for the rear about 3.5 to 4mm travel before the rear tires lift off the ground.
I hope that helps.
It is also important to stiffen up the front first, like stiffer springs or standing your shocks up more.
tommy kramer
has anybody heard of the "tommy kramer" edition sdw car? i found this setup sheet the other day. i'm not sure what it's for...
LCGv2 .. who the heck is tony krammer?
Originally Posted by pops
.....Man, I hate talking about droop. Droop gauges make it confusing as well......
Agreed! That's the first time I heard someone on this forum say that!
i dont think there is a new car coming out at the moment,. i think it is just a setup sheet that this person has changed slightly, as the actual lcg setup sheet has LCG in big letter at the top, and that doesnt. i think he has just changed a sdw sheet abit and added afew more things onto it like the suspension mounts used, i had thought of doing that but never tried it. it doesnt even seem to have the actual lcg specific settings on it like the akerman settings etc...
ON to someting
Originally Posted by MrUnlimited
What has to be changed on a perfect car ? On the sheet SDW shocktowers are displayed while the LCG has different shocktowers which are almost the same as the BD shocktowers
